Help: do I need a T-case drop? I like the clearance... - JeepForum.com
post #1 of 5 Old 09-28-2011, 08:30 PM Thread Starter
aBoyAndHisCJ
1978 CJ7
About two months ago, I installed about 4.5 inches of suspension lift, and I took the CJ-7 out for a spin yesterday. It feels so buttery smooth, I'm really impressed with my work. No death wobble, no weird steering even though I'm going to put the drop pitman arm on regardless. Now I'm wondering if I need to install the 1-inch transfer case drop kit which I already have. If I can do without it, I willó I like the clearance. What do you guys think? Anybody run a CJ-7 with 4+ inches of lift and no T-case drop? Is it mandatory & standard practice to drop the T-case, or is it more variable depending on how your particular rig runs with the mods? Thanks.
The problem with Jeeps is that everyone fancies himself some kind of Adventurer after he buys one. As if courage, or ruggedness, can be had for a mere $27,745 MSRP
aBoyAndHisCJ is offline
post #2 of 5 Old 09-29-2011, 12:08 AM
scifone
Learns the hard way
scifone's Avatar
If you aren't getting any driveline vibrations then leave the t-case drop out. The only thing it's used for is driveline vibes. Be happy you don't need it!
scifone is offline
post #3 of 5 Old 09-29-2011, 02:03 AM
mediumdaddy
if you dont have any driveline vibes, by all means dont install the TC drop. any why are you installing the drop pitman arm? there is no need for it, unless you installed a drop track bar bracket on the axle side. you'll get some nasty bumpsteer if you dont keep your track bar lined up right.
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #4 of 5 Old 09-29-2011, 05:33 PM Thread Starter
aBoyAndHisCJ
1978 CJ7
Well...my rationale was that the drop pitman arm would bring the steering components of the lifted CJ back close to the original geometry of everything right underneath the front bumper before I jacked it up. I was anticipating reduced steering quality. So no pitman arm drop unless I'm getting bumpsteer? I don't think CJs have track bars, let alone drop track bar brackets...
post #5 of 5 Old 09-29-2011, 05:48 PM
biffgnar
biffgnar's Avatar
Are you giving TJ advice to somebody with a CJ?
biffgnar is offline
cj7 , transfer case drop , u-joints
t-case drop vs. sye/cv rjt36 Engines & Drivetrain 6 08-26-2006 07:41 PM
T-Case Drop Hardware mr_user Tires & Wheels 4 06-04-2006 07:04 PM
transfer case drop Benfield Tires & Wheels 1 05-19-2006 06:10 PM
What's the highest you can go without an SYE and just a t-case drop? Achped Tires & Wheels 7 12-15-2005 04:33 PM
SYE vs. MM or T-case drop mikeythefireman General Jeep & Off-Road Equipment 18 05-29-2002 03:40 PM
