I have a Warn PowerPlant HD supposed to have 12,000 lbs pulling power. Have had for years with no issues except replacing contactor. Had under a heavy load yesterday and it quit pulling. Everything sounds normal and air compressor still works fine. It just won't pull in or feed out cable. It is not locked up either. What did I break? Everything seems to be in perfect working order...it just won't turn the cable either direction.
Have you tried flipping the brake handle locked and unlocked a few times engaging and trying to pull each time? Sometimes my warn winch is a little finicky and requires some witch magic like thAt to get it to engage
Yeah...just can't get it. Even when the winch is off and in the locked position I can still turn it easily by hand.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
