Heating trouble shooting. - JeepForum.com
post #1 of 5 Old 10-23-2013, 01:49 AM Thread Starter
jeepster02
Basically, I feel heat barely coming from my defrost vent, but its obviously not blowing. The fan speed control does nothing, no noise, blowing, just nothing. My guess is blower motor, but if anything, what else could cause this? It is in a 94 YJ. Thanks.
jeepster02 is offline
post #2 of 5 Old 10-23-2013, 01:53 AM
uberxj92
1992 XJ Cherokee
Check the relay for the a/c and blower. Check the fuses. I dint know where the blower us in s yj but you could pull the plug check for power.
If you have good relay and fuses and no power I would suspect the control panel .
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 5 Old 10-28-2013, 10:07 PM
jokerchief462
Check the plug on the firewall below the batter tray single red w/white tracer. That is the blower motor hot wire it has a case ground.
The heater control panel I think 4 screws. Pull it away from the dash slowly. The lever that turns power on to the system uses two white wires check for voltage at both sides and then move the lever make sure power goes through. If you have power there on both sides go over to the passenger side and look at the heater vents you should find a plug going to the resistor that gives you the three speeds. Check for voltage there with a meter.
Here is apic of the blower motor wire and plug
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 5 Old 11-08-2013, 06:12 PM Thread Starter
jeepster02
Great, thanks fellas. Ill have to check it out this weekend. Hopefully its an easy fix. I dont really want to dig the blower motor out to swap it.
post #5 of 5 Old 11-11-2013, 07:48 PM Thread Starter
jeepster02
Well, we found that there must be a short somewhere. So, for now, we basically bypassed and I have heat. This is just temperary until I have the time to tear into thw dash to find the short. Thank fellas
