Has Anyone Tried Mastercrafts Nomad Seats - JeepForum.com
post #1 of 13 Old 10-17-2013, 11:48 PM Thread Starter
HMFIC
HMFIC's Avatar
My drivers seat is shot and now both layers of seat covers are shot as well. I have been eyeballing the Mastercraft Nomad seat for awhile but I have not seen anyone's opinion after owning and using them.
Does anyone have these seats? If so, how comfortable are they?
http://www.quadratec.com/products/24233_3100.htm
HMFIC is offline
post #2 of 13 Old 10-18-2013, 12:51 PM
Leffnasty
Bump and sub. I have been keeping my eyes peeled for some good seats. 6'6 & 300lbs doesn't fit well in the stock seat
Leffnasty is offline
post #3 of 13 Old 10-18-2013, 01:00 PM
MWV247
Ive got Mastercrafts -Not impressed. Ive got the Baja RS seats with adj headrest. When I lean my head back its about 7 or 8 inches until my head finds the headrest. I reckon they did that for people that wear helmets. My wife and I were rear ended and had terrible whip lash and I attribute the seats as the cause. My personal suggestion is to try the seats before you buy. They do sit about an inch higher and since they have a steel frame all around they wont wear out on entry and exiting of the seat.
Dropping $1500 on seats I expected better -im sure these are cheaper though.
MWV247 is offline
post #4 of 13 Old 10-18-2013, 03:21 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have a set of the originals that I am halfway thru installing. They are much more comfy than the stockers. Originals and Nomads are similar with nomads having more cushion below you a**
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5 of 13 Old 10-18-2013, 05:00 PM
bgredjeep
1987 YJ Wrangler
My buddy bought these for his CJ. They look nice and are pretty comfy. On stock risers they are too high for tall or short people IMO. For me, my head it up in the roll bar, and shorter people will have a hard time reaching the pedals. I run susp. seats in my YJ and with a custom mount to get the height right they are excellent.
For the price the Nomads seem pretty good. No input on durability as he is still rebuilding the Jeep.
bgredjeep is online now
post #6 of 13 Old 10-19-2013, 12:39 AM Thread Starter
HMFIC
HMFIC's Avatar
I am kinda tall at 6'3" so this is good info. What kind of custom mount did you do? I have a Mig, but wonder if it is safe to cut and weld brackets for seats.
HMFIC is offline
post #7 of 13 Old 10-22-2013, 04:56 PM
bgredjeep
1987 YJ Wrangler
My corbeaus are mounted to the cage. Probably 3 or 4 inches lower than stock so I don't hit my head on the cage any more.
post #8 of 13 Old 10-22-2013, 07:15 PM
Fins
1980 CJ7
I agree with MWV247. Check out how far back the head rests are. I can wear a cowboy hat while driving my Jeep with the Baja RS seats and it never touches. I too am concerned about whiplash in an accident.
Fins is offline
post #9 of 13 Old 10-24-2013, 08:51 PM Thread Starter
HMFIC
HMFIC's Avatar
Anyone have these?
HMFIC is offline
post #10 of 13 Old 10-24-2013, 10:37 PM
222Doc
222Doc's Avatar
I went with Caribou xrs. Suspension seats are nice off road.
222Doc is offline
post #11 of 13 Old 10-25-2013, 09:58 AM
Leffnasty
How are those? Any problems or concerns with the placement of the headrests?
post #12 of 13 Old 10-25-2013, 10:51 AM
222Doc
222Doc's Avatar
well the seat is made for 5 point harness's and that is how I have it.
leaning forward headrests you might want take outs from a new jeep.
once you are strapped in the head is more the angle of back seat if vertical. you wont get whip lash unless you have NO head rest. High backs are fine. whip lash is caused by the rear forces; your on a low back seat and hit from the rear. your back is stopped by the seat. But not your head it continues to stretch over the seat, whip lash.
but I am one of the few that think all these modern over thought out safety systems are not reliable. I have proof too, but digress.
222Doc is offline
post #13 of 13 Old 10-25-2013, 08:51 PM
Fletchlives85CJ
I found this thread just after I bought these for my CJ. I am a weathered 40 yr old with a bad back living in the canyons near the central coast of California, my road is unimproved dirt/really bad asphalt for 20 minutes every day...These seats are awesome! Had Best top seats before, and they sucked a...lot. Iwould put these on a riding lawn mower if I owned one. To be specific, the back rest is firm, but the base, while also firm has a really nice cushiony flex to it when you hit high frequency bumps. The deep sides are just as hard to dis/engage you butt from as any other true bucket seat, and require a lil bit of technique getting in and out (might wear on the material on contact points there over time). They are very light weight also if that is a concern. mine bolted right up to the factory seat risers with no drilling. I ditched my stock sliders that were shot, and I like the seat height. I am 6' 2" and not slim....shorter people might need to move the mounting foreward, but should be simple with a rechargeable drill motor...
Fletchlives85CJ is offline
