#121 | |
ZJjazzyJim
Must have pics
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#122 |
I just got mine today! From costco for $48. Great deal and it works really well.
I am going to try to install mine on the driver's side battery tray, but it is a tight fit. I am thinking about spinning the head unit 90 degrees to the right (looking down from the top) and mounting it sideways. I would also have to move the foot braces 90 degrees to the side. This way it won't be so tall and will fit under the master cylinder. Plus, the gauge will be at the top and the male connector will be to the side. There shouldn't be any negative effects of having it mounted on its side, right? Does anyone have a write up and/or pics on how to permanently wire it?
2004 TJ Sahara Dana 44 Black Dual Tops w/Tinted Windows Full Traction 3" Lift w/ M-Force Monotube Shocks Superwinch EPi9.0 w/ Viking Synthetic Trail Line 33" Goodyear Wrangler MT/Rs, Spidertrax 1.25" Wheel Spacers Rubicon Rocker Guards, MasterFlow OBA |
#123 | |
Your mom's favorite
It's going to be a little while before I can dig in that deeply.
Lack of planning on your part does not constitute an emergency on my part. '88 YJ, 33's, auto, begging to be modded. Can't wait!
#124 | |
here's where I had it mounted initially (if someone wants to make it no clicky that'd be nice...) ![]() that didn't work as the nuts I put underneath hit the tray mounting bracket. several repositions later I finally put it here... ![]() There was tray bolt that I was unable to put back in, so I used it to mount the compressor into one of the nuts welded on the bottom of the tray. ![]() The switch end of the compressor hangs off the end of the tray and I had to remove that bracket from the end to get the whole thing back under whatever that PITA black brake-related drum above the tray is. ![]() Anyway, due to my frustration I inadvertently forgot to put the pressure gauge back on when fitting it the last time, and wouldn't you know it, now it doesn't fit back there at all. No problem though I wanted to replace it anyway, I'll just find one that connects by tube and velcro it to the side if I have to...
Join these groups... NGJC #4 - VA Jeepers - LJ Owners "I'm not a Republican because I grew up rich, but because I didn't want to spend the rest of my life poor, waiting for the government to rescue me." MH The less a man makes declarative statements, the less apt he is to look foolish in retrospect. - CR Finally, a word to those of you out there who have yet to be offended by something I have written or said: Please be patient. I am working as fast as I can. - AC |
#125 |
double post
#126 | |
Tray mount
I ran into that on my first TJ. On the next one I cut a piece of 1/8" AL that matched the tray and mounted it on standoff's so that I could bolt things to the plate and then reattach the plate to the tray. Ron
#127 |
ZJjazzyJim
Longspoon - nice job. Drop on by Autozone and snag one of the Slime branded handheld pressure gauges. Threads right in, and it's more accurate than the POS they put on those compressors. Tire side of the gauge threads right off, and it threads perfectly into the housing.
#128 | |
Really
Really... That would be great. Can you post a photo of the gauge? I'll buy one today. Ron
#129 |
ZJjazzyJim
![]() The silver collar just threads off, the pin is stationary - you can grind it down if you'd like, but it fits inside the housing without modification, so I wouldn't bother. ![]() I used copious amounts of teflon tape on it to protect against leaks ![]() Here's my finished product - plumbed in a T so I can do dual inflation should I ever want to. Got my CO2 setup shortly after the compressor mod, so haven't tried out the dual hose. 150PSI with almost unlimited CFM kinda trumps this little weakling ![]() ![]()
#130 |
Thanks
Very nice... Thanks a lot.. Can you believe that folks couldn't give the little compressors away when they first came out near two years ago? Everyone closed them out for $19.95 and I just missed it.. Ron
#131 | |
King of the hill
Jeep garage: 2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0 1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold 1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac 2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud? |
#132 |
Junior Member
I wouldn't recommend mounting that compressor where it could pick up any water or moisture. I had mine installed in the same place you did, and during a big downpour, it got wet and never worked again. i got a new one and mounted it on the rear wheel well, right by the seat belt.......
[IMG] [/IMG]Last edited by Toltecatl; 07-30-2007 at 07:10 PM.. |
#133 |
ZJjazzyJim
Come to think of it, at the very least, I would put some kind of plastic bonnet over the air filter, and maybe put a thin bead of RTV around the switch housing. Everything else should be okay.
#134 | |
Your mom's favorite
That being said, I just tossed mine after about a year of use. It took a beating and it appears that this last time the heat from the motor running melted the glue of one of the 4 magnets inside the base and shifted it about 3/4". Then once it shut down and the glue cooled, it's now stuck in that position. I've got pics I will post here in a little while, just have to take them off the camera and then resize them. It did air up pretty close to 250-300 tires during it's lifetime. But now I'm going to look at other compressors until this winter when I work on my on-board after I get a house (with garage) this fall.
#135 |
ZJjazzyJim
Didn't think of the heat generated by the engine/headers. Good point.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
