#91 | |
ZJjazzyJim
Very clean - nice job!
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#92 |
Question for those that have replaced the air outlet with fittings for standard quick disconnect hoses and chucks.
Do you run the compressor when it is not connected to a tire (into a closed air line)? Since the compressor does not have a pressure switch, how much pressure will these small units build? Could it be hard on the compressor or the air lines/fittings? I'd like to put a standard fitting on my Costco unit, so I can use the same lines as my CO2 tank. But I'd like to get some input on these question first.
Art '01 TJ RE 3.5" Springs, JKS UCAs & LCAs, JKS front and rear adjustable trackbars, OME shocks, JKS Quicker Discos, AA SYE and TW CV driveshaft, KOZ Offroad rear bumper & swingaway carrier, D30 front w/ Detroit TrueTrac, D44 rear w/ Detroit TrueTrac, AR Baja rims, Goodyear 33x12.5 MT/Rs. |
#93 |
ZJjazzyJim
The short amount of time I had the compressor on without being connected to a tire flat-out scared me. I just watched the pressure build. I fear it could be enough to blow a hose. You can use standard fittings, but I wouldn't turn it on until it's got something to fill (tire, tank, etc)
#94 |
buy a pressure relief valve......
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#95 |
ZJjazzyJim
I guess you could put a relief valve inline between the housing and the hose. Especially after you do the 1/8" to 1/4" conversion. Dunno what kind of pressure the housing handles, so I don't know how sensitive of a relief valve you'd need.
#96 |
I picked up the Costco compressor a couple of weeks ago after reading this thread. I used it last weekend to air up after a few days of trails and it worked flawlessly. Thanks for recommending it!
#97 | |
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters |
#98 |
For anyone that can't get the little Master-Flow compressor locally, I noticed in my latest JC Whitney catalog that they are now carrying it online. Its $69 but its definitely a great little compressor. Sorry if this was already posted.. but I don't think it has been.
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000376741/mediaCode-ZX/appId-100000376741/Pr-p_CATENTRY_ID:100000376741 |
#99 |
Also... apparently 4wd.com carries them too. This is the same one I got from Pep-boys.. it works great.
http://www.4wd.com/productdetails.aspx?pid=MV50 |
#100 |
Oops, sounds expensive!
I was driving the Hyundai around (Jeep is at the Dealer/another story) and picked one up for myself today at Costco. This happered to work out great because I was on my way to wally world and blew a tire going into the parking lot.
I got the spare on quick, but as I lowered it to the ground I found that it was way low on air. So I pulled my new purchase out of the trunk, out of it's box and aired it up. I didn't time it, but it worked fast enough for me. Free replacement of the blow out from Discount tire and were on the road again.
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon Stupity Kills, but not nearly enough. |
#101 |
Super ObA!!!!...I've just picked up on and tested it out on a 31x10.5/15 and from 0-30psi the little sucker did a heck of a job--3mins flat.....It's the best bang of the buck I've seen Lately...and I'm sure going to pick me up another one.
#102 |
I picked one up also, it jinxed me however, I had a flat today and needed it. $10 rebate at Pepboys. I'm going to dig through this thread again and find a replacement for the guage, nowhere near accurate. But, I'm happy with the compressor. I expected it to sound like a bunch of tin cans strung to the back of a car, but it's smooth and quite. May get another for the family car.2 Thumbs-up.
97ZJ 00WJ-Sold 90 Comanche Pioneer 4x4, 3inches, 31's SOLD 89 Comanche Pioneer 2wd 97 Wrangler Sport |
#103 |
ZJjazzyJim
For a gauge, go over to Autozone and get the Slime 0-60 gauge. It's like $3
#104 |
But regardless, the reading is not going to be accurate while pumping. You need to stop the compressor to get a pressure reading of the tire. Right?
1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
#105 |
ZJjazzyJim
Correctamundo
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
