Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
#346 | |
What parts do I need to convert the air fitting on the Pep Boys one to a normal size?
#347 |
I've had the HF Compressor for about a year, used 4 of 5 times. It started blowing fuses. I took it apart and found the cylinder scored and covered with some kind of black stuff. tried cleaning everything up but it only ran a short while and blew the fuse. I just got the red master flow. I'll see how well it holds up.
#348 |
Can anyone tell me the best way to hardwire it? Where should i buy the wires to hardwire or should i just cut off the clamps and use the wires on it?
#349 |
Well...I just found this posting while searching for different ways to add OBA. I just spent about an hour going through the whole thread looking for pictures of peoples different setups. Does anyone have pictures of it setup with a tank and what is needed to have the pump fill the tank? Also, if using a tank, will it be able to provide sufficient air to power an impact gun if needed on the trail?
97 TJ, d44 arb locked, 2.5" bds lift, 35" tires, JKS adjustable control arms |
#350 |
Guess I need to go visit CostCo tomorrow... Thanks for the review!
*2000 TJ* - Long Arms - Big Tires - Chrome Shafts - Locked and loaded + Body Armor *1988 325iS* - Coils - 24v Swap - Sways - Road Warrior |
#351 |
Wow!!!
Wow! Thanx
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it..... 2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos |
#352 |
The costco by me didnt have them. Has anyone recently found one there? Ifso ill check some of the others around town.
#353 |
they have them on ebay.
#354 |
Pep Boys Has them....
#355 |
amazon has them for 59 bucks.
Amazon.com: Q Industries MV50 SuperFlow Hi-Volume Air Compressor: Automotive |
#356 |
Same price at Pep Boys
#357 |
Great thread! I picked up the MF1050 unit at Pep Boys during my lunch break. It was $59.99, but I had a $5 coupon.
I can't wait to get home to test it out. I plan to mount it under the hood and hard wire it. Thanks again for all of the helpful info. Now I can use the money I saved not buying a Viair to tackle other things on my "to do" list. |
#358 | |
#359 |
#360 |
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
