Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
#16 | ||
i'll be going to costco today!!
superb comparison!! ![]()
#17 |
Don't forget about the mods you can do on the Costco model to inflate 2 tires at once. Actually mine is a MV-50, but looks the same. See my gallery.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, 10 ply., Maxxis Bighorns, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker. Next year? : Rear bumper with tire carrier. |
#18 |
Do it right or not at all
![]() Join Date: Jan 2003
Very nice writeup and comparison, maybe I'll pick up one of the Costco compressors as a backup for my York-based OBA. Ya never know. This comparison is good enough that you ought to place it in the Reviews section where it can be referenced in the future.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#19 | |
about how long does it take to air up two tires with your splitter on the compressor?
Sport TJ build everything below has a hyperlink to the install/review Rubicon Express Long Arm D30 Alloy axle shafts with Alloy U joints D30 Powertrax no slip locker Skid row skids engine- gas tank - radiator- steering box Expidition one trail series rear bumper and carrier Edge Trail jammer install/review Bestop Trailmax Aqua seat Bestop Super top Before you ask about a product in the Technical forums check out the product review section! |
#20 | |
Brake Wizard
Exactly twice as long as it takes to air up one. |
#21 | |
Uncle Paul has spoken...
My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com) |
#22 |
I found this one on their web site, I wonder if it's similar? Seems to be a different brand.
http://www.costco.com/Browse/Product.aspx?Prodid=11196210 |
#23 | |
Actually, in the description it says its a Master Flow. But, they obviously look different. |
#24 | |
I'll try it
#25 |
I do two tires at once and though from an airing up only time point of view it's no faster, the complete process is actually faster overall. Both tires fill to the exact same pressure and I only have to mess with getting the pressure exact once per side. My 4-connector octopus air rig has been cut back to 2 connectors on one hose due to the two air hose tangling thing and it works really well now.
#26 |
Nice write up.
I've had a cheapo air compressor get so hot the cord melted. |
#27 | |
Have Jeep, Will Travel
Great write up! My only question is why didn't you do it 6 months ago before I bought the more expensive version of the Harbor Freight compressor?
Drew Quote:
#28 |
Great write up! We don't have any Costco's around here so I did some searching and found that PepBoys has the Master Flow for $54.99 and had a $5 off coupon on-line you could print out. I went today and got one and they also have a $10 Rebate thru March 3rd so with Tax the total cost was $43.48
#29 |
Im getting one from Pepboys this weekend , where you get the coupon? I may hook a small air tank to mine with a pressure switch.
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters |
#30 |
Go on-line to PepBoys.com and register for on-line specials and then you can go to printable coupons. As far as the rebate they have forms there.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
