#211 | |
ZJjazzyJim
I'm sure you can get one from the manufacturer, but I'd just re-plumb it to use standard fittings. The ones the mfg put on are goofy, so a standard quick-disco chuck won't fit on it. Re-plumbing doesn't take any time at all...cakewalk.
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#212 | |
yeah, but i misplaced it.
i wonder if the 20pc air accessory kit would work. the one from pep boys and home depot???
#213 |
ZJjazzyJim
That was what I used, just got mine from Harbor Freight. You'll need to adapt the size from the pump housing to the fitting - do a search for the modifications and you'll see what you need.
#214 | |
got a pic???
#215 |
ZJjazzyJim
Start here:
http://www.jeepforum.com/forum/3643965-post81.html Then use the search - I did a writeup on it some time ago.
#216 |
Just purchased the new Q-Maxx Air Compressor. MP-1052 from amazon $48, shipped. Cant wait to try it out. Thanks for the post
Dana 30 True Trac, Dana 44 Track Loc 4.75" Hybrid Lift - 4" IRO Coils, IRO UCA, Teraflex LCA, RE Shocks 16x8 Cragar - 285/75/16 KM2 IRO Sliders |
#217 |
i bought one from costco, it works just fine more my 33" tires, plus its 20 bucks less then the magezine price
#218 | |
Junior Member
What size connector are people using to replace the silver proprietary end? Thanks, Bob |
#219 |
ZJjazzyJim
I'm 99% sure I used 1/4" fittings from the hardware store. I guess it's possible that it doesn't truly fit right, but I've got enough teffy tape on the threads that it's holding. It definitely threaded in well for me.
#220 |
Well, to contribute to the thread, I don't think you can beat the little red compressor (whichever name you call it by) for the price! Here is mine...
![]() ![]() ![]() (after some suds and bubbles...) ![]() I have the red plastic filter piece and the handle sitting on my workbench and I was going to throw them out, but if anybody wants then they're yours for the cost of shipping. I know somebody must want that filter... Last edited by rmb2485; 02-18-2008 at 04:54 PM.. Reason: Added clean engine pic because the dirty ones are terrible! |
#221 | |
Junior Member
Another idea I had is to tap the fitting to work, this isn't something I have a lot of experience with so might not be the best. . . Bob |
#222 |
ZJjazzyJim
I'm very concerned about yours not threading clean like mine did. I almost wonder if they did something goofy with that thing.
If teflon tape doesn't do it, you should probably drill and tap it to fit whatever size fitting you prefer. You would want to drill it out completely and tap accordingly.
#223 | |
Now in the 937
So I have the MF1050 compressor hardmounted under hood. Love it for airing up tires... I was wondering if I could find a link as to how you wire in a pressure switch so it cuts off when it reaches "x" psi(I'd like to use an auxillary tank to eventually run lockers, air horn, etc).
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#224 |
Does anyone know where to get the costco unit in canada? I was just about to order the ARB high output, when I came across this thread! It seems like they are comparable units if you don't have lockers.
#225 |
Well, I did some research on it an it looks like the MV50 and the MF-1052 are exactly the same.
MV50 on Amazon. http://www.amazon.com/dp/B000BM8RT8?smid=ATVPDKIKX0DER&tag=pricegrabber2-auto-20&linkCode=asn MF-1052 on Amazon. http://www.amazon.com/gp/offer-listing/B000NCO6D2/ref=dp_olp_2 The MV-50 is $12 cheaper though, I think. If you don't believe me here is a write up about the MV-50. http://www.parksoffroad.com/prodreview/inflatortest/mv50/mv50.htm |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
