Got a free winch.....that doesn't work. need help! - JeepForum.com
post #1 of 17 Old 08-15-2009, 11:26 PM Thread Starter
_TIM_
So today I scored a free Smittybuilt XRC8 and winch plate for my jeep. But it does not work. When you try to winch it in, it sounds like the winch is working, but it does not pull in the line. It will free-spool but not winch in or out.
Is this a problem that can be fixed? I believe that it has the warranty from Smittybuilt but if it doesn't, I want to have a back up plan to make this thing work. The winch has been used less than 10 times and never abused.
Any advice/ideas?
Thanks
Tim
1998 tj|chili pepper red|
_TIM_ is offline
post #2 of 17 Old 08-15-2009, 11:28 PM
WhiteOut
WhiteOut's Avatar
It sounds like the solenoids in the control box are shot, Smittybuilt might have a rebuild kit for a good price.
WhiteOut is offline
post #3 of 17 Old 08-15-2009, 11:32 PM
SteelBlue_WJ
SteelBlue_WJ's Avatar
atleast you arent out much money lol, so the between the winch and therebuild kit it shouldnt be too bad of an investment
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #4 of 17 Old 08-16-2009, 08:01 AM Thread Starter
_TIM_
Thats exactly why I took it, I figure if i have to spend a little bit of money to fix it its still better than buying a new one. Ill have to call Smittybuilt on monday and ask them what my options
_TIM_ is offline
post #5 of 17 Old 08-16-2009, 08:19 AM
jgorm
jgorm's Avatar
IF it sounds like its working its not the solenoids and probably the clutch. Does it freespool while you try and winch in?
jgorm is offline
post #6 of 17 Old 08-16-2009, 08:40 AM Thread Starter
_TIM_
Not sure, hopefully going to do some testing before I have to go into work today. If it does free spool when winching, what does that mean?
_TIM_ is offline
post #7 of 17 Old 08-16-2009, 09:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If the motor runs in both directions but the hub doesn't turn, it sounds like the clutch mechanism or planetary gearset is bad, not the solenoids. If it was a solenoid(s) causing the problem, the motor wouldn't run.
Jerry Bransford is online now
post #8 of 17 Old 08-16-2009, 10:00 AM Thread Starter
_TIM_
Assuming that I can get the parts to fix it, how difficult do you think it would be to replace them? Since the motor does turn I'm thinking that Jerry is right and that my clutch could be shot. Is this something that can be replaced or does it mean the winch is useless?
_TIM_ is offline
post #9 of 17 Old 08-16-2009, 02:47 PM
Jerry Bransford
Administrator
While it's very easy to replace solenoids, I'm not so sure about anything mechanical on that particular winch. A call to Smittybilt's customer service dept. is in order.
post #10 of 17 Old 08-16-2009, 06:35 PM
KJFactor
Just start taking it apart. Have an exploded diagram view and go to town. Go to the website and download a diagram. I got a free Superwinch and pretty much did the same thing. Spent a couple hours for 2 days lubricating and cleaning the winch. I learned a lot by just taking things apart. Other than that Xtreme 4x4 did a transmission and WINCH full rebuild episode this weekend. Have fun.
-1994 Wrangler:D44&Ford9,fuel cell,stretched,aluminum rockers and corners
'94 Wrangler on 37" SOLD. I hate I don't have a Jeep
GOD WILL JUDGE OUR ENEMIES...WE'LL ARRANGE THE MEETING
KJFactor is offline
post #11 of 17 Old 08-16-2009, 08:13 PM
ET48
Last December I blew the clutch after using it only 4 times. It did the exact same thing as you describe. I still had the warranty and they came and picked it up and gave me a new one. Haven't had any problems with this one yet. But what do you expect for a $300 china built winch? (In your case free )
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #12 of 17 Old 08-16-2009, 08:17 PM
surfsup887
yeah there was a full winch rebuild on xtreme 4x4 this morning. take a look and see wha he did. from what he described, it sounds like the solenoids
Built Not Bought #133
Looking for a 33 in R16 tire any condition in MA or RI
surfsup887 is offline
post #13 of 17 Old 08-17-2009, 04:23 PM
KJFactor
From what the OP said it would sound like it's winching in but wouldn't move. So I would agree with JGORM that it is not the Solenoids. If it was the solenoids their would be no noise as if it's trying to winch in. (No electricity getting to the motor)
KJFactor is offline
post #14 of 17 Old 08-17-2009, 08:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Most of the winch motors I've pulled out used a "woodruff" key to secure the drive gear on the end of the motor shaft. Maybe that sheared? As mentioned, I'd print out an exploded view diagram, and carefully start taking it apart until I found out what happened...
BESRK is offline
post #15 of 17 Old 08-17-2009, 09:18 PM Thread Starter
_TIM_
Thanks for all the advice guys. I think my first move is going to be calling Smittybilt and seeing what they say. I don't want to tear into the winch and then have them tell me I voided the warranty. Im thinking it is the clutch so when I call them Im going to see about getting new parts, and hopefully Ill have a working winch within a week or two.
_TIM_ is offline
Free / cheap protective winch sleeve LaJeepermln General Jeep & Off-Road Equipment 26 11-26-2009 10:43 AM
Koenig winch won't free spool. Help. asoude1 General Jeep & Off-Road Equipment 1 08-31-2009 05:47 PM
Trouble with winch - won't free spool jhunt87 General Jeep & Off-Road Equipment 1 07-25-2009 02:41 PM
free winch 6,000lb littleman66 General Jeep & Off-Road Equipment 15 01-31-2005 11:46 AM
Free winch? Good deal? ProfessorCRX General Jeep & Off-Road Equipment 10 01-12-2005 12:29 AM
