Quantcast Ford 8.8 identification - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Ford 8.8 identification
Old 01-10-2006, 12:13 PM   #1
Tri_X_Troll
1986 MJ Comanche
I could've sworn that there was a sticky for this popular upgrade, but since I can't find it.....
I'm thinking about dropping an 8.8 into the TJ and was curious if there was a pattern to finding out what gears an 8.8 would have based on the drivetrain options of the donor vehicle. My jeep has the 3.73 gears and I would like to go to the 4.10 gears, so an 8.8 that already has the 4.10 gears would let me get away with only having to regear the dana 30. While I'm in the junk yard, what year explorers should I be targeting and what engine tranny combo's would have the 4.10 gears?
Ryan- "I went from one crap-tastic drive train to another. At least the engine is the weak link this time"
Tri_X_Troll is offline   Reply With Quote
Old 01-10-2006, 12:35 PM   #2
What The?
Wrong forum, this is what you are looking for:
http://65.42.106.152/forums/showthread.php?t=674123
Look at the diff plate:
Specs:
Code Capacity Ratio
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
L - Limited Slip Differential
C - Conventional Differential
Make sure you visit http://car-part.com/
Joe
What The? is offline   Reply With Quote
Old 01-10-2006, 12:36 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I researched this awhile ago, and found that some Limited models have 4.10 gears. Here's a great link to a website with all specs for all years:
http://www.carsdirect.com/researchcenter/factsheet_features?make=FO&modelid=87&acode=USA60F OS105B0
One particular model with 4.10 is a 96 Eddie Bauer model. Navigate around the site I linked above and you should find a few others.
Here's another link that breaks down the axle ID codes (scroll down about half way):
http://www.therangerstation.com/tech_library/Axles.html
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 01-11-2006, 12:01 AM   #4
Jeep wanna Be
There should be a little metal tag on the diff cover that should say something like 4L10 which is 4.10 limit slip, or 3_73 for 3.73 open diff,
Jeep wanna Be is offline   Reply With Quote
Old 05-08-2009, 11:56 PM   #5
treefiddyYJ
So now that we know it is an 8.8, back to my original question... I know the F150 8.8's are like 69" whereas the preferred Explorer 8.8's are like 60". Should I install this axle as-is or should I have it shortened, and how much does it cost to shorten axles?
treefiddyYJ is offline   Reply With Quote
Old 05-09-2009, 01:46 AM   #6
treefiddyYJ
What about running it full width and getting a similar width front axle?
Old 05-09-2009, 03:16 AM   #7
RogueSpear2023
JF is my second home.
I don't believe F-150s ever had a ford 8.8 I think they would may have had a Ford 9" back in the day, more recently I believe it to be 10.25 Sterling. Also do the OP, instead of regearing your front axle to 4.10 why not get one from a 4cyl, the would have the 4.10 gearing, and would be a direct bolt in. They are fairly cheap from the junk yard, or in the classifieds here. Also if you are dead set on regearing something get a High Pinion Dana 30 from a XJ, that is also a direct bolt in, and would be considerably stronger than a LP Dana 30.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Old 05-09-2009, 03:17 AM   #8
Mean Max
Mean Max's Avatar
You'll want one from an Explorer. '95-'01 will get you rear disc brakes, earlier models will have drums.
Look on the driver's door of the donor Explorer for the axle code on the VIN sticker.
Explorer 8.8 Axle codes
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
Specs:
Code Capacity Ratio
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
Code Ratio
41 3.27
43 3.08
42 3.45
44 3.73
45 3.55
47 4.10
72 3.08C
74 3.45C
82 3.08C
84 3.45C
85 3.55C
86 3.73C
87 4.10C
89 (1992-1998) 4.10C
89 (1999-2001) 4.56C
91 3.27C
92 3.08C
95 3.55C
96 3.73C
97 4.10C
F4 3.45L
F5 3.55L
F6 3.73L
F7 4.10L
K6 4.10L
D2 3.45
D4 3.73L
D7 4.10
R5 3.55L
R6 3.73L
R7 4.10L
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 07-30-2009, 03:27 AM   #9
DirtNMyTeeth
thanks for the good info
DirtNMyTeeth is offline   Reply With Quote
Old 07-30-2009, 09:23 AM   #10
asf06
the f150s and broncos did come with 8.8s. i am currently rebuilding one. '93 F150
ford used the 8.8 in a few vehicles- mustang, ranger, explorer, bronco and f150. obiously the truck axles were full width. the 9s were used in 250s in the 70's i believe (FW) and the early (66-77) bronco (NT). there was also an HD 9, but idk what that was put in; maybe a diesel or a dually? i couldn't tell you about the 10.25. in recent years the 250s used 60s, 350s used 70s or 80s. there might be a few others but i don't know what trucks they were put on.
the gear ratio is stamped on the side of the ring gear. mine says 355
hope this helps
1993 YJ, too broke to swap the tranny and my 60s
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
PIKE Jeepers #1
Jeep Smokeless #4
asf06 is offline   Reply With Quote
Old 03-15-2010, 11:20 PM   #11
FL_Curb_Crawler
Holy thread revival!
I just picked up an 8.8 today and want to know more about it. I have been searching for 2 hours now and can't find what I'm looking for. The axle was already removed from the vehicle so I could not check the VIN on the side of the door. It did have a metal tag attached to the diff cover. It reads
"S612B"
"3 55 88 7F09"
Does anybody here speak code? If so I could really use your help.
FL_Curb_Crawler is offline   Reply With Quote
Old 03-16-2010, 01:49 AM   #12
FL_Curb_Crawler
Nothing?.....
Old 03-16-2010, 11:10 AM   #13
Wheelin98TJ
JEEP FREAK
"S612B"
"3 55 88 7F09"
That is an 8.8 axle with 3.55 gears and an open diff.
Here is an example of a Ford tag:
98 TJ
Old 03-16-2010, 03:43 PM   #14
FL_Curb_Crawler
Thanks man. That really helped.
Old 04-13-2011, 12:31 PM   #15
IRISHXJ
1989 XJ Cherokee
ok so i have a ford 8.8 that i cant find the diff tag on no idea what it came out of except my roomate THINKS it was an early 90s f150, which meshs cause its got the drum settup i just wanna know how i can figure out what gears this thing has in it w no id tag any help?
IRISHXJ is offline   Reply With Quote
Glock Forum
