Flex; How much is really necessary? - JeepForum.com
post #1 of 18 Old 02-04-2005, 09:23 AM Thread Starter
makizoo
I understand the concept of more flex allowing you to keep all 4 on the ground for added traction, and all the ramp shots are pretty impressive. But you drive up and back down. How does this help in the real off road world going forward? After you get the front tire on and over an obstacle, won't you still hang up on the frame, lower, control arm, or t-case skid, before the rear tire can get you over?
makizoo is offline
post #2 of 18 Old 02-04-2005, 09:38 AM
UPnOVER
UPnOVER's Avatar
That way you need big tires and a wheel base that will fit your needs.... If you going to center your self by going straight…..Don’t... Go at an angle....
I get older and they stay the same age.
RED JEEP #6
91' YJ, D30 EZ, F8.8 locked & 410's, BDS4+" lift, 35" BFG's on 15x8 RC, 8,000lb Ramsey, etc.
rock-nutz.com
UPnOVER is offline
post #3 of 18 Old 02-04-2005, 12:00 PM Thread Starter
makizoo
Figured that much, but then isn't just the tire size the most important? To close up the wheelbase, and lift only as required to squeeze in the tires? So the height of the lift becomes more important than its ability to articulate?
makizoo is offline
post #4 of 18 Old 02-04-2005, 12:47 PM
lupinsea
lupinsea's Avatar
How much flex do you need? It depends.
I think largely it'll depend on on the terrain you want to run. Mud bogs or sand dunes and the like I would imagine wouldn't need as much articulation as, say, rock crawling with boulders the size of cars.
I've setup my Jeep with the goal of being able to run 95-97% of the trail miles in my state. I figure it's not worth the huge monetary investment to me to be able to conqure the last 3-5% of the trails. Sure, I might be missing out on some really gnarly stuff . . . but so is my wallet. And the compromises that are needed to get to that last little bit don't interest me. Jeeps are expensive enough without adding uncessary damage to repair into the mix.
That being said I find that for what I want to do the approx 30" of articulation I have is sufficient and pretty easy to achieve for a very moderate price.
I'm still impressed with what is essentially still a stock Jeep suspension. All that I've added to get to this point is a $200 BB, $70 BL, and the Anti-rock (though disconnects would work, too). Very good road manners and very good off-road prowess, too to yeild a good balance.
Oh, and if you're worried about dropping off the other side of an obstacle and messing up your tub . . . find a way to install some sturdy rocker guards.
- Jay
lupinsea is offline
post #5 of 18 Old 02-09-2005, 01:47 AM
RideRed04
RideRed04's Avatar
Flex is over-rated. This is JUUUST about full stuff on my YJ, she's still got a bit more. I have a spot on each front fender that's dented up from the tires.
If you are locked up front and rear, having a ballanced suspention that keeps your rig planted firmly will get you much farther. I thing f/r weight ballance is more important then flex.
2000 WJ Limited 4.7 QD
RideRed04 is offline
post #6 of 18 Old 02-09-2005, 07:43 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
In my opinion, the only time you need a lot of flex if you do not have lockers. Lockers don't mind of one tire is in the air, but an open diff does.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #7 of 18 Old 02-09-2005, 08:20 AM
AudioGuru
AudioGuru's Avatar
Having all 4 tires on the ground is the key to traction and stability, one can never have too much flex. Just because one has lockers and they can pull if a tire is up doesn't mean that all you need to do is add lockers to a stock height SE and you can wheel almost anything.
Aws you can see, if I had more flex, I wouldn't have gotten tripped up here.(second picture adjusted for level)
Don't lie. God said so.
AudioGuru is offline
post #8 of 18 Old 02-09-2005, 08:26 AM
CJ51973
CJ51973's Avatar
I think the flex gives you a little better balance. Prior to these springs I ran stock ones. They didn't flex. I had more "tipping" issues.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #9 of 18 Old 02-09-2005, 11:41 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Ooohhhh... love your '73 CJ5! I helped a good friend do a frame-up restoration of his and it turned out gorqeous. That year's flat instrument panel and the AMC 304 V8 some came with have me lusting after a '73 myself!
Getting
Jerry Bransford is offline
post #10 of 18 Old 02-09-2005, 12:07 PM
RideRed04
RideRed04's Avatar
You have more then enough flex for that situation. There are a few better lines I can see there that would have made it much easier. Too much flex can be bad, trust me. Sometimes it's an advantage to have more tire pressure on one tire, and alot of flex prevents this. Super flexy rigs are also very unstable unless they are VERY low. I'm not saying weld your axles to the frame, I'm just saying more then a well tuned suspesion system really doesn't help much offroad.
I second Jerry, that '5 is SEXY!!!
post #11 of 18 Old 02-09-2005, 02:42 PM
AudioGuru
AudioGuru's Avatar
Yes, there are better lines. But more flex would have helped. That's my point.
I was leading the group in unfamiliar territory without a spotter.
post #12 of 18 Old 02-09-2005, 02:54 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Yes, there are better lines. But more flex would have helped. That's my point. I was leading the group in unfamiliar territory without a spotter.
Did you get through? Probably. There is never enough flex to keep all the tires on the ground at all times in all situations. If you know your flex capabilities, whatever they are, you pick lines that you can work with. I have less flex than you, manage to go everywhere I want, and rarely get tippy. Oh yeah, and in situations like you are in the pic, I always have a spotter to help pick the line more likely to keep 4 on the floor, or tell me all is well or not if less than 4.
Web Admin for
post #13 of 18 Old 02-09-2005, 02:59 PM
RideRed04
RideRed04's Avatar
That doesn't even look like you would really need a spotter there...just turn your wheels to the passenger side and let the jeep go into that crack. If I'm ever out with buddies and not sure, I'll just get out and walk around all the angles, sometimes there is a really obvious line that you can't see from the drivers seat.
post #14 of 18 Old 02-10-2005, 06:55 AM
CJ51973
CJ51973's Avatar
A good walk through can save a roll cage check
CJ51973 is offline
post #15 of 18 Old 02-10-2005, 09:35 AM
AudioGuru
AudioGuru's Avatar
We were concerned that merely going right would cause a flop, since the weight was going to transfer quickly from driver's rear to passenger's front. We strapped back up the hill 1 foot and then I got the right line, it was cake after that. The crumbling bank didn't inspire much confidence, either.
Max. Flex vs. Useful Flex and The Anti-rock lupinsea General Jeep & Off-Road Equipment 117 03-20-2014 08:03 PM
Flex Sambox Tires & Wheels 4 07-25-2007 11:55 PM
most flex out of a cv ? 360wrangler Engines & Drivetrain 1 07-05-2007 04:07 PM
Too much flex! mudmonkey2400 General Jeep & Off-Road Equipment 20 04-17-2007 02:03 PM
How can i get better flex? 93jeepyj2.5 Tires & Wheels 10 07-21-2002 07:35 PM
