Fire Extinguisher? - Page 9 - JeepForum.com
post #121 of 152 Old 09-10-2012, 05:17 PM
sjones26573
Originally Posted by sjones26573 View Post
Bumping an old thread because this is the best extinguisher thread out here and I'm not about to add another to the 100+. I've been looking to pick one up after so many burning Jeep threads. I'm looking at a 5lb extinguisher in either BC or Purple K. I was leaning toward Purple K since one can has about 2x the fire suppression of an equal sized BC can. Only question is, are there any bad downsides to Purple K?
http://www.trianglefireinc.com/Amere...FQsFnQodyHAAtQ
Bumping mine
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #122 of 152 Old 09-19-2012, 07:28 PM
spbarone
2015 JK Wrangler
Bumping mine
Just ordered a couple from that site. Hope to have them in this weekend!
spbarone is offline
post #123 of 152 Old 09-20-2012, 10:13 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Originally Posted by Jerry Bransford View Post
To me, a 2.5 lb. fire extinguisher is just too small, not to mention a 5 lb. extinguisher fits those locations you mention just fine... see my post earlier in this thread showing how I have mounted a 5 lb. extinguisher there. If you're going to go to the trouble of mounting two, I'd sure pay a tad more and go with the more useful 5 lb. size since it fits there fine.
Think about where offroading typically takes place... out in the boondocks where it will take a fire truck a long time to get to. I just can't go along with a 2.5 lb. extinguisher being a serious/realistic size extinguisher for remote offroad locations. And there is no need to order an extinguisher, any local hardware store like Lowes, Home Depot, etc. has them in stock... including the more recommended 5 lb. size models.
I agree with Jerry
I'm reminded of a conversation with the old geezer that used to check and service the fire extinguishers at my last employer, who told me:
"You're better off peeing on a fire than using a 2.5lb extinguisher"
I'm open to discussion on types though. If you can get twice the fire control from Purple-K at the same volume, I'm dang interested.
I'm thinking I should talk to the fire extinguisher dealer that I get my CO2 fills from. Wanna make sure I'm carrying the best I can carry, for the best price and the most convenient size.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #124 of 152 Old 09-20-2012, 10:45 PM
407863
Purple K aka PKP should never bee mixed with ABC dry chem because the mixing will destroy its efficiency. Purple K is used in oul raffineries and where flammable liquids are beeing handled. The main component is about 78-82% sodium bi carbonate. Its a free flowing, lighter than most liquids and does not wet with water and is well compatible with most foam concentrates. It is most effective agains class B ( flammable liquids) and ENERGIZED electrical equipment. It is 4-5 times more effective against class B fires then CO2 and more then teice then Sodium Bicarbonate. It works by inhibiting the chemical chain reaction ( smotheres the fire). Ingestion of large amounts can cause alkalosis. Hope that helps
407863 is offline
post #125 of 152 Old 07-01-2013, 08:22 PM Thread Starter
5artist5
5artist5's Avatar
1972 CJ5
Originally Posted by FPKites View Post
I agree with Jerry
I think that a 2.5 pound extinguisher is worse then none in a lot of cases because it gives a lot of people a false sense of security. I think two 5lb bottles should be a minimum. One for the driver and one for a passenger.
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline
post #126 of 152 Old 07-02-2013, 05:47 AM
TJ_Virgin
2.5lb = 1A:10-B:C
Fire extinguishing capacity is rated in accordance with ANSI/UL 711: Rating and Fire Testing of Fire Extinguishers. The ratings are described using numbers preceding the class letter, such as 1-A:10-B:C. The number preceding the A multiplied by 1.25 gives the equivalent extinguishing capability in gallons of water. The number preceding the B indicates the size of fire in square feet that an ordinary user should be able to extinguish. There is no additional rating for class C, as it only indicates that the extinguishing agent will not conduct electricity, and an extinguisher will never have a rating of just C.
TJ_Virgin is offline
post #127 of 152 Old 07-03-2013, 01:59 PM
mrott
I read through about half of the thread and I didn't see too much insight as to good practices of using extinguishers on car fires... to preface the remainder, I'm a Battalion Chief with my local fire department. I've seen it, studied it and done it... This is my general "rule of thumb". It certainly doesn't work all the time but it's my go-to technique.
To start with, the easiest type of fire to put out tends to be an engine compartment fire. The main reason most engine compartment fires get out of control are due to one major issue...people open the hood. If the hood is closed, it limits the amount of oxygen that can get to the fire giving more time for remediation. Less oxygen means the fire won't grow as big and as fast (no oxygen means no fire). There are two decent ways to put out the engine compartment fire. The first could be by using the extinguisher through the front grille (if you can hit the air intake with CO2 you could also stall out a car). My preferred method is to use a pick axe or something equally sharp (halligan bar) to put a small hole into the hood and put the hose of the extinguisher up to (or in) the hole and start discharging. The third is simply a deluge of water which will probably cause the insurance company to total the vehicle anyway.
The discharge of a dry chem plus the fact that the hood is still closed (limiting the amount of oxygen) will put out a decent sized fire with not a lot of extinguisher.
I will say that this works when you catch a fire as it starts. Once it gets going, you might as well just sit back and watch since the vehicle is going to be totaled anyway.
Another major issue is when it's a fuel fire. It's very difficult to put out a fuel fire without foam. Best bet is just hope to not have a fuel fire.
mrott is offline
post #128 of 152 Old 07-03-2013, 02:36 PM
biffgnar
biffgnar's Avatar
X1000! As some of you know I was recently in a fuel fire while co-driving in NORRA Mexican 1000. The ferocity of that fire in the cab since it was a mid engine car was terrifying. Fortunately for us when master off switch was killed the fuel pump stopped feeding the fire and a regular extinguisher got it out quickly. I took the worst of it (three weeks in hospital and two grafting surgeries) but the damage to the car was repairable and it was back on course on day four and took the checkered flag in Cabo. Safety gear (firesuit, helmet, helmet skirt, etc.) did their jobs otherwise it could have been really serious for me. Being in that fuel fire is an experience I wouldn't wish on my worst enemy.
Oh, and I agree 100% about the comments about oxygen level under hood. Another time in Maine with my TJ I had leaking transmission fluid ignite on the minicats. We could see it under there burning with very small flame. We quickly got the extinguisher. When we popped hood it flamed way up but a quick direct shot with extinguisher got it and didn't get extinguisher crap all over engine bay. Only worked because we got it fast. Otherwise when we opened that hood the oxygen to the flame not good.
Romney in 2020!
biffgnar is offline
post #129 of 152 Old 07-03-2013, 02:38 PM
Filthy-Beast
I've seen no mention of Halguard in this thread from what I've read it's very good at putting out vehicle fires and does not leave a residue or damage electronics. Anybody have any experience with these?
http://www.h3rperformance.com/halguard_products.htm
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #130 of 152 Old 07-03-2013, 02:46 PM
TJ_Virgin
I still have a 3# halon 1211 in my closet. I think it might find a home in the jeep.
post #131 of 152 Old 07-03-2013, 03:09 PM
mrott
I would not want to experience that and wish it on no one... Fire protection suits and equipment are wonderful things.
Basically, it's a really expensive extinguisher....
From what I've read about them, their rating and abilities aren't much if any better than a traditional dry chem extinguisher. The biggest difference is the lack of powder. If you're in an enclosed environment then it absolutely makes sense to try to use something that isn't going to suffocate you. Trying to breathe in that powder is a real b****. If I'm outside with a vehicle fire I'm not worrying about the powder.
The other consideration, yes... the powder will make a mess. Well guess what, you more than likely have quite a bit of work to do in order to fix the fact that the vehicle caught fire. Besides, a power washer is a wonderful thing.
Also, at least my hope is that I'll be using my extinguisher on someone else's vehicle rather than my own. I don't expect for them to pay to refill/recharge my extinguisher so I'm going to use the cheapest, most effective option. It's the same opinion with my fire trucks. If I'm putting out the fire from the truck, the fire has probably been burning for a while so the vehicle is already totaled. I just need something simple and efficient to put it out.
mrott is offline
post #132 of 152 Old 07-03-2013, 05:42 PM
biffgnar
biffgnar's Avatar
Shot of my fire suit for fun that could have been me (I could post some pictures of the burns but those definitely NSFW). Helmet skirt has similar burn marks on it. Helmet doesn't show marks but I'm sure my hair would not have done well with the flames. In addition to the burn marks you can see on the suit it has a bunch of burned plastic (or some chemical) from the "melting" seat stuck to it that could have been really nasty if it was stuck to my skin.
Romney in 2020!
biffgnar is offline
post #133 of 152 Old 07-03-2013, 05:55 PM
wilson1010
I really don't want to go back and read all of this narrative about fire extinguishers for off road rigs. Of course, I have a couple little dry chemical extinguishers in my rig. But, they are mostly for show. If your rig catches on fire the smartest thing to do is get the hell away from it, let it burn and try not to get anyone hurt. Professional firefighters with big time equipment and dressed for action are sometimes injured from car fires and an untrained person with a 5 lb or 10 lb hand held unit and no fire protection gear on is just a big mess waiting to happen.
Try insurance instead, Its cheaper and safer.
Now for a kitchen fire extinguisher, or the garage or the grille, nothing can beat a 20lb CO2. That's what I have and there is no clean up, works like magic and is a lot of fun to play with if you get bored. Anything you point a dry chemical unit at is ruined. Not so with CO2.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #134 of 152 Old 07-03-2013, 06:28 PM
biffgnar
biffgnar's Avatar
Just to complete the thought on my prior posts, agree 100%. The burns I suffered were in the short period of time that it took to release a five point harness, get a window net down and dive out the window (with my helmet comm and blower still attached). It was the main power shutdown and my co-driver (who didn't get burned) and the chase crew from another race team who happened to be right behind us getting extinguishers on it that put it out. Don't mess around if you have a fire.
Romney in 2020!
biffgnar is offline
post #135 of 152 Old 12-27-2013, 07:03 PM
jeepinhokie
How does this one stack up?
Got it as a Christmas present.
HOKIES UNITED!
jeepinhokie is offline
What to look for in a fire extinguisher Rush1184 General Jeep & Off-Road Equipment 20 09-23-2011 03:12 PM
CO2 OBA from fire extinguisher, CJATE General Jeep & Off-Road Equipment 10 07-21-2007 02:09 AM
fire extinguisher frumpy General Jeep & Off-Road Equipment 8 07-03-2006 01:04 PM
Fire extinguisher dirtbagofva General Jeep & Off-Road Equipment 10 12-08-2005 12:31 AM
Fire Extinguisher FlyersFan2009 General Jeep & Off-Road Equipment 8 12-28-2004 10:17 PM
