Quantcast Fender Flare Gap/Sag? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Fender Flare Gap/Sag?
Old 07-22-2008, 08:52 PM   #1
willydigger
Thanks for the Upgrade!
willydigger's Avatar
Is there a difference in fender flares with regards to how they are designed, to eliminate or minimize the gap between the body and the flare?
I installed some used Xenon 6 inch flares (not tube style). While removing the factory flare, I noticed it had a small "lip" around the outside edge so when it was installed it would fit tight against the body. The Xenon flares were completely flat and the bolt hole was bulged so it created a minor gap between the body and flare.
I don't know how old these flares are, but I was wondering if the new Xenon or Warn flares are made with a "lip" to prevent the gap problem. I would assume large flares (especially rubber Xenon's) would eventually sag and form a gap regardless. I've seen several pics on the forum with flares that seemingly meet flush with the body, but I can't figure if it's better design or just a new flare.
For those of you with 6 inch flares, have you run into a sag issue or noticed a difference between the design of the factory and aftermarket mounting side?
Here is the underside of the Front Passenger Side Flare front:
Here is the underside of the Front Passenger Side Flare back:
WHODEY
willydigger is offline   Reply With Quote
Old 07-23-2008, 10:49 AM   #2
dabprice
I have the Xenon (Flat) Flares. They do not fit perfectly flush to the Jeep but they did not sag or gap. I stuck some 3/8" half-round vinyl trim in the crease. It looks and works perfectly:
dabprice is offline   Reply With Quote
Old 07-23-2008, 11:53 AM   #3
willydigger
Did you buy them new?
WHODEY
Old 07-23-2008, 11:58 AM   #4
willydigger
Did you buy them new? Was the mounting side flat?
WHODEY
Old 07-23-2008, 07:49 PM   #5
dabprice
Yes, I bought them new about a year ago when they first came out. I don't recall that there was anything wrong or odd with the mounting side.
Old 07-23-2008, 09:39 PM   #6
Recoil
Keyser Soze
Recoil's Avatar
can you throw a couple more pics on here of them on your Jeep
www.indyorv.com
EPIC
Recoil is offline   Reply With Quote
Old 07-24-2008, 07:05 AM   #7
willydigger
Here is the mount side of the extension. Notice the dark line at the top. This is the lip.
Rear Front Gap:
Rear Top Gap:
Jeep Overall:
They don't look bad until you get up to them. Especially the rear flares. The front does it too, but only a little.
WHODEY
Glock Forum
