Engo E10000 Winch Review - Page 4 - JeepForum.com
post #46 of 107 Old 04-03-2012, 02:54 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Originally Posted by bseblfrk09 View Post
Read the shootout and you will actually understand what is going on...
I've read it. Thank-you.
My winch that died was not an Engo. It was the brand new 5hp series wound winch from a company with a name that starts with an "S", and ends with a "T". You can fill in the rest.
Who knows, you may have great luck with your winch, and I hope you do.
Oops, never mind.
They have not been out long enough to have any real world, long term reliability data. The specs seem very close to my previous winch though.
TJDaveX is offline
post #47 of 107 Old 04-03-2012, 03:10 PM
MayRoll
Originally Posted by Ross View Post
As far as the battery consumption, that doesn't concern me.
Why not Ross? We all know even at high idle, battery drain is going to happen. I watched a friend's Mile Marker fail to recover a stuck 1/2 ton during an 80ft pull through deep mud. Battery strength went down to around 12.2V IIRC. And failed to start the Jeep once he shut it off (to this day I don't know why he turned it off to begin with). Those long hard pulls made me think twice about amp draws.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #48 of 107 Old 04-03-2012, 03:56 PM
ClimbStuff
Even though it didn't survive...
Yup. Think about it this way. By having it break the gears out of it at 8 tons, you know it's way overbuilt for its 4.75 ton rating. The remarkable thing is the motor, even at the fastest loaded pull speed (and still the coolest as well), was still pulling at 8 tons, and strong enough to rip apart quality gearsets. Whilst it did ultimately fail at 168% of its rated duty, it makes a pretty good point and shows all its cards about how well it really is built. If nothing else, take away that it is overbuilt by an excessive margin, not by a perfectly acceptable 10 or 20%, but like all things, it will eventually fail.
The real hero of the test IMO, was the T-Max. It was rated for the same load, and stalled at the same 8 tons, but worked totally fine afterward. It was a bit slower, a bit noisier, was probably packaged by a 9 yr old, and as a newer brand, doesn't have the track record behind it that Warn does, but based soley on performance, I'd call it the winner. We don't really know if it was a fluke, or that is an accurate representation of T-Max standards, or what sort of circus might come after a breakdown. Overall though, not having owned either brand, and based only on the data in the test, I'd pick the T-Max. Only time would tell if it was a better choice though.
ClimbStuff is offline
post #49 of 107 Old 04-03-2012, 03:59 PM
Ross
I haven't had that problem. I also have not shut my jeep off after long pulls. Even if one pulls longer than the other maybe the increased speed would make up for it but probably not. I suspect the reason the Warn draws more power is because it pulls faster. For me I would rather have the faster pulls.
The longest pull I did was a couple hours. We used two jeeps and each had a winch so there were breaks. My buddy had a s Smitybilt so my breaks were very l o n g as I waited on him. Neither one of us turned off our jeeps. Towards the end we stopped using the Smitybilt because I could move, winch and reset faster than he could just winch.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #50 of 107 Old 04-03-2012, 07:15 PM
HighRoller02TJ
Originally Posted by Siva283 View Post
I got a 10,000 pound one a month a.d a half ago. It arrived damaged fought with them for 3 days they decided it was just the solenoid even though I told them the winch itself seems damaged too. So another week and I get the solenoid. Now the motor tried to spin but can't cause the gears are bound up so bad that hitting the button for literally a second to try to bump it and the positive wire terminal on the motor started smoking and melting the plastic boot. I paid for this winch 5 weeks ago. It has yet to work. Now I have to call and probably fight them for another week and then they will probably want me to take it apart again for something that won't fix it eithier. So a month and a half with a broken winch and counting. Glad yours worked though. Their customer service is the worst I have ever dealt with ever.
a month and a half ago?? you got it 2 weeks ago. this guy lies so much.
HighRoller02TJ is offline
post #51 of 107 Old 04-03-2012, 07:25 PM
HighRoller02TJ
You better recheck your dates. You might want to spend 5 minutes on Google to she how many reviews match mine. Now as I have told you before don't be a keyboard cowboy. Come say it to my face instead of hiding behind your keyboard. It is hilarious though that your butt hurt over something that doesn't involve you. You have been following me around all day its said. Get on with your life. You want to order from them order from them no skin off my back. If it goes good great for you if it doesn't remember what you read. A t minute Google search will validate everything I said.
you are right, i will drive to maryland and say it to your face
post #52 of 107 Old 04-03-2012, 07:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've had to winch my TJ off the trail three times when I couldn't start the engine before starting to winch myself. Once when the steering box blew its seal while I was doing Sledgehammer in Johnson Valley (below pic) and twice more from bad ignition coils. All three times involved winching my TJ over rocks to get it off the trail so others could pass me during my repairs. With just one battery in my TJ, I was able to start the engine after making repairs without needing a jumpstart. That's not to say you can do long hard pulls without the engine running but just doing a normal Jeep pull isn't necessarily going to drain the battery either.
On some of the arguments above from those who claim they want their winch to be able to be pull more than their winch is rated for, be aware that the typical 5/16" wire rope only has a 9.8K minimum breaking strength and it can and will break at loads under 10K lbs. Milemarker's old Milemarker vs. Warn video showed that quite well. Even 3/8" wire rope can and does break at loads under 15K lbs, it's minimum breaking strength is only 14.4K lbs.
Cool video on that at
Rope specs at http://www.masterpull.com/cpage.cfm?cpid=197
The below pic is cool in that a friend was photographing my TJ after a climb up Sledgehammer when the steering box blew its seal, you can see it puking its power steering fluid. Which is why I couldn't start the Jeep for the winching episode, that would have forced the PS pump to run dry.
Jerry Bransford is online now
post #53 of 107 Old 04-03-2012, 07:55 PM
ClimbStuff
Cool video on that at http://www.youtube.com/watch?v=GDJ3Q...dYzUrnig2TI53o
How did you end up getting the steering box fixed? I can't imagine that's a common thing for folks to carry spares of lol.
post #54 of 107 Old 04-03-2012, 08:15 PM
Jerry Bransford
Administrator
No kidding. I was shocked when Blaine Johnson sent his wife Kat back down Sledgehammer and she came back 45 minutes later with a bagged and tagged rebuilt Tommy Lee steering box to match what I had. That is why we call Blaine's collection of spare parts 'The Magic Parts Box' since it always seems to have whatever is needed. We all carry lots of spare parts though, those trails require them. That is fellow JF moderator Joe Dillard giving me a much needed hand and moral support.
post #55 of 107 Old 04-03-2012, 08:17 PM Thread Starter
bseblfrk09
The funny thing is that you started the argument that the Warn only broke after pulling 16.5k lbs. So you are saying that Warn is better because it pulled more before exploding, but I am the stupid one for claiming that I want a winch that doesn't explode if stalled out? What exactly happened to this quote Jerry?
"On some of the silly arguments above from those who claim they want their 9-10k winch to be able to pull 12,000 lbs. without breaking should be aware..."
Why did you edit this?
bseblfrk09 is offline
post #56 of 107 Old 04-03-2012, 08:22 PM
Jerry Bransford
Administrator
I've said what I wanted to say, I'm don't feel the need to waste any more time with you since all you like to do is spin things to what suits you... which is why I already pegged you as The Spin Doctor earlier... a title I've never before bestowed anyone. There are some people worth the time and trouble of discussing things with, others just aren't.
post #57 of 107 Old 04-03-2012, 08:22 PM Thread Starter
bseblfrk09
I am aware of all the safety issues that go along with winching, and I would never overload my winch. Rather my argument was that if my winch should be overloaded I would like that it worked afterwards.
post #58 of 107 Old 04-03-2012, 08:29 PM
Jerry Bransford
Administrator
With this, I'm done with you... should you ever have the need to load a winch to 16,500 lbs that would break the Warn 9.5xp, be my guest. Not to mention your winch cable would snap before that point.
Sayonara, go practice your spin techniques with someone else.
post #59 of 107 Old 04-03-2012, 08:30 PM Thread Starter
bseblfrk09
I just take things for what I read. I just hate people who think that they are superior because they have more money and can buy an over priced winch. These type of people will never give credit where it is due because if you don't have the "best" then you aren't worth talking too. I started this thread to give honest feedback about a product that I purchased. Yes it may not be the brand that you recommend because it doesn't have a name. I am trying to give it a name. So why do you have to come in and tell me that what I bought is inferior? In my opinion, if you aren't here to ask questions about the product, or share your experiences with this product, then you shouldn't even be posting here.
post #60 of 107 Old 04-03-2012, 08:41 PM Thread Starter
bseblfrk09
It is people like you that make this forum obnoxious to even post in. Yes you are full of very useful knowledge, and this is a place to share that knowledge. Yes you think yours is best, but do you have experience with an Engo? Not many people do, and I am trying to alleviate some of the false beliefs that a Warn is your only option if you want a good winch. There are people like me that can't afford $1200 for a winch but still enjoy wheeling. These people need a good reliable winch just as well as you do. They would like info on this product, not someone saying it sucks because it isn't a Warn. So on that note why don't you go post somewhere else where your knowledge and input is actually needed.
engo winch? jager00 General Jeep & Off-Road Equipment 21 11-01-2012 11:05 AM
Engo 10K winch reflections thread unrealtrip General Jeep & Off-Road Equipment 5 06-18-2012 10:51 AM
XRC8 Smittybuilt Winch review ncarr General Jeep & Off-Road Equipment 10 12-16-2008 07:33 PM
Harbor Frieght winch review Wrangler11 General Jeep & Off-Road Equipment 12 01-05-2007 01:23 AM
champion 7500# winch review iwishihad1 General Jeep & Off-Road Equipment 6 11-24-2006 01:46 PM
