Engo E10000 Winch Review - Page 3 - JeepForum.com
post #31 of 107 Old 04-03-2012, 08:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by bseblfrk09 View Post
Regardless of what it pulled, every one of those winches were pulled to their max. Yes the engo may have been 3000 pounds less, but that was still its max and it didn't fail. Only 2 winches survived the same exact torture and the Warn failed. You can praise Warn all you want but what is the point of having a winch that can pull an extra 3000lbs and fail at the end. I would much rather have a winch that pulls only 12000lbs and still be able to make another pull if need be.
Pretty funny... the Warn pulled to over 16,000 lbs. before failing and you find fault with that.
Not that we could ever get our winches to pull 16,000 lbs. except in a test lab.
Jerry Bransford is offline
post #32 of 107 Old 04-03-2012, 08:53 AM Thread Starter
bseblfrk09
16,000 lbs doesn't help if it explodes when it gets there. What do you do when you max it out, it explodes and you need it again in the same day? I would rather have a winch that stalls at 12,000lbs but doesn't explode. In which case I could add another pulley to the mix and try again. There is no trying again if it explodes.
bseblfrk09 is offline
post #33 of 107 Old 04-03-2012, 09:07 AM
Jerry Bransford
Administrator
You're really complaining about a 9500 lb. winch failing at 16,500 lbs.? Congratulations on being a great spin doctor.
post #34 of 107 Old 04-03-2012, 09:09 AM
Siva283
I agree with this. I would rather it stall at it rating and work again. You can always try again. And it will still work tomorrow. If it explodes its done till its rebuilt or replaced. No second try.
Ask me how I know...
Siva283 is offline
post #35 of 107 Old 04-03-2012, 09:31 AM
KevKaos
Its starting to smell like a men's urinal in here.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #36 of 107 Old 04-03-2012, 09:57 AM Thread Starter
bseblfrk09
Great for Warn. They can build a winch that costs 4x the amount of my Engo and for that low low cost you get a winch that will pollute water (so much for treading lightly), fail to pull even half of its line before draining a battery, and explode after pulling 16,500lbs. But I will tell you what they do do well. Their controller is definitely better than Engo because it "feels better" in your hand. They also make really good stickers! Oh, and don't forget they buy their way to the number one spot in winch shootouts because they were out performed by winches a quarter of the cost!
Instead I will take my Engo which will not pollute water, almost finishes the pull without draining a battery, and stalls out at a weak 12,000lbs and does not explode. Instead it allows me to step back, rethink my strategy and try again. It also came with a wireless controller (so much for Warn's controller being so much better). Oh, and yes it is a whole 3 decibels louder than Warn.
post #37 of 107 Old 04-03-2012, 11:21 AM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Instead I will take my Engo which,..... almost finishes the pull without draining a battery,........
I lol'd on that one. Thank you for that.
Message sent from previous new technology Chinese winch owner. His winch died before it was two years old, and he now owns a Warn.
TJDaveX is offline
post #38 of 107 Old 04-03-2012, 11:29 AM
KevKaos
If I see someone stuck with a dead Chinese winch, I'll winch them out. I'll laugh at them a bit first, but I'd still pull them out. In all fairness though, if the roles were reversed, I would expect the same treatment.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #39 of 107 Old 04-03-2012, 11:53 AM Thread Starter
bseblfrk09
Ya because an Engo leaving 22 ft of line is terrible compared to Warn thst leaves 58 ft...
post #40 of 107 Old 04-03-2012, 11:56 AM Thread Starter
bseblfrk09
Read the shootout and you will actually understand what is going on...
post #41 of 107 Old 04-03-2012, 12:16 PM
ClimbStuff
ClimbStuff is offline
post #42 of 107 Old 04-03-2012, 12:36 PM
Ross
Originally Posted by ClimbStuff View Post
Seems Warn was their top choice.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #43 of 107 Old 04-03-2012, 12:54 PM
ClimbStuff
Yes. More importantly though, was this line:
In conclusion, while all of the winches in this test have strengths that distinguish them, the Warn 9.5xp is the most recommendable winch of the group we tested.
They identify that every winch had certain qualities that make them desirable, they just felt the Warn was the most well rounded.
post #44 of 107 Old 04-03-2012, 01:00 PM Thread Starter
bseblfrk09
Even though it didn't survive...
post #45 of 107 Old 04-03-2012, 01:31 PM
Ross
Mine has survived 11 years now. But I do agree with you, I would rather have it stall at a lower pull the break at a higher pull. As far as the battery consumption, that doesn't concern me.
Ross is offline
engo winch? jager00 General Jeep & Off-Road Equipment 21 11-01-2012 10:05 AM
Engo 10K winch reflections thread unrealtrip General Jeep & Off-Road Equipment 5 06-18-2012 09:51 AM
XRC8 Smittybuilt Winch review ncarr General Jeep & Off-Road Equipment 10 12-16-2008 06:33 PM
Harbor Frieght winch review Wrangler11 General Jeep & Off-Road Equipment 12 01-05-2007 12:23 AM
champion 7500# winch review iwishihad1 General Jeep & Off-Road Equipment 6 11-24-2006 12:46 PM
