engine starts by jump, but eventually dies - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > engine starts by jump, but eventually dies
Steering and more from Ruffstuff!Rough Country Deals at JeepHut.comThe Ruffstuff 14 Bolt Complete Swap Kit!
Unread 05-08-2006, 06:03 PM   #1
iwishihad1
hey everybody
well me and 2 friends found a 95 ford bronco 2 for 200 bucks being sold. a small tree fell across it, and broke out 2 windows, but other then that its in great shape for only 200 bucks. but we found a problem. it starts with a jump, runs, and eventually dies, and wont start unless jumped. ive heard alternator, battery, and carberator. any otherthings i should look into... this things goin doorless, chopped top, lifted, wheels, and were gonna wheel it till it dies, and not have to worry about damaging out daily drivers
iwishihad1 is offline   Reply With Quote
Unread 05-08-2006, 06:29 PM   #2
Andrew F
I would start with the battery. It's probally the easiest to check. Either swap in a battery you know works or get it tested at a auto parts store or a shop. From there I would go to the alternator, you can get that tested also.
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
[SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE]
Andrew F is offline   Reply With Quote
Unread 05-08-2006, 06:52 PM   #3
Bgeddes
Ridin' with the King
I don't think a '95 Bronco II would have a carburator. As far as I recall all the B2s after '90 were EFI.
'05 KJ CRD and '00 XJ Classic > Stock DDs
Wanted - Early CJ - running but restorable
Bgeddes is offline   Reply With Quote
Unread 05-08-2006, 07:15 PM   #4
fried_gold
Sounds like a dead cell in the battery so I agree, start by checking or swapping the battery
fried_gold is offline   Reply With Quote
Unread 05-08-2006, 08:33 PM   #5
iwishihad1
i thought the battery only had to do with getting it started, but from there on electrical things like starter, alternator, and battery didn't matter.. forgive my ignorance
Unread 05-08-2006, 09:17 PM   #6
fried_gold
You're right, and I don't know how it works, but I had a dead cell and it acted just like that. Had to jump it off, it kept dying and needed jumped off again etc. It may not be a dead cell but it sounds a lot like it and the battery is the easiest thing to check by doing a quick swap
Unread 05-08-2006, 11:01 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
An engine with an alternator won't run with a dead battery. Only older cars with generators could run without the battery.
The alternator cannot produce any power at all... zero, nada... unless it is getting a 12 volt "exciter" voltage from the battery. If the battery is dead, the alternator can't produce power because it's not getting its exciter voltage from the battery so your engine won't get any spark.
Replace the battery.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 05-09-2006, 10:45 PM   #8
Jermy01
1978 CJ7
i had the same thing happen to my jeep, but it ended up being the alternator. took it into pep boys (i know i know, but it was the closest place)....they tested it and said it was good. took it to my real shop after i couldn't find anything else wrong and he rebuild the alternator because there was too much oil and dirt in the alternator.
-Jeremy
1978 CJ7, rear locker, 31'' BFG mud Terrain, superior axles. RE 2.5" lift. 304 V8. Warn M8000. All for now, but cant wait to get more
Jermy01 is offline   Reply With Quote
Unread 05-10-2006, 11:01 AM   #9
rouxbicon
Probably meant '85, since B2's ended after '89, and were basically replaced by the Explorer in '90.
'03 red Rubi
rouxbicon is offline   Reply With Quote
Unread 05-10-2006, 06:37 PM   #10
iwishihad1
ok.. so i got a brand new battery from my house tonight and we went out and it fired right up, ran great for about 2 mins. reved from idle up to close to limiter with no sputtering. then all of a sudden it started to bog, and died, after that it wouldn't start. it does this every time it sits for a while. any ideas now??
Unread 05-11-2006, 11:12 AM   #11
smartshot
just wondering did you check your fuel pump, fuel filter, coil wire?
smartshot is offline   Reply With Quote
Unread 05-11-2006, 04:56 PM   #12
Hunter9
x2 just had this exact problem, bought a yellow top and away I went.
[CENTER][COLOR=White]97 Sport [/COLOR] 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
[COLOR="Red"]Former 3.07 Gears Club Member #1[/CENTER][/COLOR]
Hunter9 is offline   Reply With Quote
Unread 05-11-2006, 05:48 PM   #13
iwishihad1
smartshot.. were thinking fuel pump right now. it gets PLENTY of gas for 1-2 mins, then just bogs and dies out. how are we supposed to check that
thanks
Unread 05-11-2006, 06:41 PM   #14
BluesMan
Had this happen in a 68 Firebird - Alternator
...Don't follow Chili Palmer into the trees...
BluesMan is offline   Reply With Quote
Unread 05-11-2006, 06:53 PM   #15
iwishihad1
i dont understand what an alternator has to do with this though. thats what a bunch of people keep telling me, but i just dont see how that could be it, i kind of understand what an alternator does, but not fully
