04-06-2008, 06:02 PM
#1
Easy to install Kc HiLites?
I'm thinking about getting 2 Kc 100 watt HiLites but I was wondering how hard they are to install. quadratec says they are easy, but I don't know much about electronics or wiring or any of that stuff. Do they come pre-wired or have instructions? I was planning on mounting them on my windshield
KC HiLiTES 6" Round SlimLite Series Driving 100W Super White Halogen
04-06-2008, 06:10 PM
#2
I put KC SlimLights in my '06, on the stock front bumper. No problem, all the wiring came with the kit from Q'tec. Probably less than an hour. Ran the switch to the center of the dash, and pulling the dash and getting the switch installed took the longest.
Good project for a summer afternoon. I shouldn't think you'd have many problems.
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
04-06-2008, 06:30 PM
#3
Does it have instructions and everything for like installing the switch and stuff? I have tons of tools in my garage, but without my dad here I don't know much about anything mechanical or electrical.
04-07-2008, 11:36 AM
#4
I put KC Highlighters on my bumper and they were a snap. KC also uses a cool switch that is better quatity than most I've seen.
Silver '06 TJ w/ neat stuff on her!
"New" 1987 YJ Project for my son!
04-07-2008, 04:53 PM
#5
Instructions for wiring came with my kit, and were easy to follow.
No instructions on how to mount the switch in the Jeep, of course - they can't possibly outline everyplace that you could mount a switch in a T.J.
You can read up on it -
http://www.stu-offroad.com/electrical.asp
and
http://www.stu-offroad.com/electrica...6/switch-1.htm
and
http://www.stu-offroad.com/electrica...ogswitch-1.htm
I figure the two hard parts for you -
1. Running the wires through the cowling to the inside of the cab; look in the electrical forum here and you'll see several threads if you search on "cowl". Here's one with pics:
http://www.jeepforum.com/forum/f9/windshield-mounted-hellas-524557/
2. Installing the switch. You'll have to decide where to mount it. Getting the dash apart is really easy, Rocky529 posted this in another thread:
"There is a long piece that runs along the length of the dashboard (has the defroster grill as part of it). Gently pry that up, and take it out. Next, you will see 2 screws holding on the radio/HVAC bezel. Unscrew those. That bezel also pops out...Btw, the smoker's package on '03+ TJs consist of an ashtray that sits in one of the cupholders, not part of the bezel anymore."
It's a fairly simple installation - really not electrical experience is needed with the instructions.
If you plan to wire to the factory fog lamp switch instead of the Qtech switch, search the electrical forum and you'll find some helpful hints there.
I'm attaching a small photo of my switch panel. Check my gallery for a better photo.
HTH
Jim
04-07-2008, 10:05 PM
#6
FmrVette Hey thanks for all your help. I have a yj, so would it be much different for getting the wires through the cowl and dash fairly similar? And could you resize that pic, its super small.
04-08-2008, 06:15 PM
#7
Wow, everything I've been able to find is for the TJ.
Here's a site you might like for YJ reading:
http://www.jedi.com/obiwan/jeep/mods.html
but nothing on how to run the wiring thru the cowl of a YJ.
Maybe post over in the YJ tech forum and ask?
I'd have to assume it wouldn't be all that much different; I had a 95 YJ but never ran electrical through the cowl. The dash, of course, would be different - but still shouldn't be much of a trudge. Jeeps are really pretty basic vehicles.
On the pic, I can upload a bigger one when I get access to my files (they're on a computer I don't have with me right now) but you can get a good look if you go to my gallery and click on the photo - it will enlarge for a better view.
Jim
04-15-2008, 08:41 PM
#8
Originally Posted by FmrVette
On the pic, I can upload a bigger one when I get access to my files...
Sorry it took so long to get back to ya.
Pics:
Jim
04-15-2008, 09:35 PM
#9
Wow that looks really good. Im going to put off on the lights for now, this weekend im getting a new front bumper, and then 2 weeks after that (when I get paid  ) im probably getting my cb
09-02-2009, 04:14 PM
#10
Hey I just bought some new rocker switches to put into the dash of my 06 tj. Where are the bolts located that need to be removed to pull of the center dash console?
09-02-2009, 06:09 PM
#11
I was worried about installing mine too. But the harness comes complete and all you have to do is connect the fuses and relays (easy), connect the battery, ( super easy) and then run the wires (hardest part, I did it 3 times until I found a way I liked), and mount switch. (idiot proof).
KC did a good job on their kits, I must say.
2002 WJ - Forest Green
09-04-2009, 06:59 AM
#12
You guys like the slim lights or somthing else?
My Build
www.jeepforum.com/forum/f22/building-roxy-860189/
01-16-2010, 04:53 PM
#13
Nahh man this should be easy for you. The brackets for the windshield dont require any drilling so you just need a allen wrentch. And the wiring part is easy too. I have 4 on my roof and i just ran it down the door and threw the fire wall and hooked it directly to the batterie. You should not have any problems on this.
| Suggested Threads |
- Cheap and Easy Stereo Install - Electrical, Audio, GPS, & 2-Way Radio (2 replies)
- Kc HiLites help - Electrical, Audio, GPS, & 2-Way Radio (0 replies)
- Soundbar, easy to install? - Electrical, Audio, GPS, & 2-Way Radio (1 replies)
- KC Hilites - General Jeep & Off-Road Equipment (1 replies)
- V8 in a 93 YJ. How easy is it 2 install? - Engines & Drivetrain (3 replies)
