Eagle Rim model/cleaning questions - JeepForum.com
post #1 of 4 Old 11-01-2011, 05:54 PM Thread Starter
Rubes
Hi, all...bought this TJ over the summer and have a couple questions about the rims.
Anyone know which model number this is (see below)? I've checked out aewheel <dot> com and found it's close to series 101 (14 hole), but mine have the 18 bolt heads on the edge of the rim.
I want to replace the center caps -- 2 of them are cracked. I believe it is a 15x8. How do I know which size center cap to look for?
Finally, there is a lot of corrosion on 4 of them. It appears to break off easily if I lightly scrape. How should I clean/polish it? It appears to be circa 2004 (year of the TJ) and they'res a lot of corrosion around the lug areas.
Thanks in advance! (Sorry for the picture size).
Rubes is offline
post #2 of 4 Old 11-01-2011, 07:12 PM
Vin
IMHO Don't use wax, as tempting as it is. I did on my Bajas and the wax burnt on and stained the rims. Mcguires makes a good wheel cleaner.
Vin is offline
post #3 of 4 Old 11-02-2011, 08:46 AM Thread Starter
Rubes
OOPS! Too late...I applied Liquid Glass on the spare last weekend.
Does McGuires remove the corrosion? Just wondering how people remove corrosion from the alloys, then treat. Like I said, I lightly used a 1-inch wide putty knife/scraper and corrosion fell off. It didn't scratch much at all. I'm not ready yet to paint them.
Rubes is offline
post #4 of 4 Old 11-03-2011, 08:47 AM Thread Starter
Rubes
XX Bump...Buehler?
Rubes is offline
Those of you w/ info on eagle alloy CCJ Tires & Wheels 4 03-31-2009 08:09 AM
American Eagle 057 Copenhagen1 Tires & Wheels 3 12-15-2006 09:52 PM
1984 AMC Eagle 00Vert Engines & Drivetrain 0 03-04-2006 01:20 PM
Anyone with Eagle 589s....... Wildbill Tires & Wheels 11 06-26-2003 03:00 PM
eagle alloy 058 or M/T II thomascw Tires & Wheels 6 06-07-2003 02:59 PM
