durango steering box pros/cons - JeepForum.com
post #1 of 17 Old 09-27-2013, 02:04 PM Thread Starter
uberxj92
1992 XJ Cherokee
I've read a lot about the mod. I want to know what you all have think or have experienced with it. Steering radius is my biggest concern. I run the Rusty's heavy duty steering under knuckle.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #2 of 17 Old 09-30-2013, 06:07 AM
eduardostewart
i bought one and rebuilt it. you can grind down the bump stops on the end cap/plug and then remove the big snap ring on the inside to give you all the turning ability the box can give. now i just need to adjust the steering bump stops on the axle, though that needed to happen even beforehand anyway
eduardostewart is offline
post #3 of 17 Old 09-30-2013, 08:49 AM
biffgnar
biffgnar's Avatar
I'm sorry!
biffgnar is offline
post #4 of 17 Old 09-30-2013, 12:27 PM Thread Starter
uberxj92
1992 XJ Cherokee
Lol. It came with an 8.5 la lift, brand new pro-comp 12x15 6" offset rims, 35x14.50x15 pit bull crawlers (brand new), all on a 1988 xj. The lift was installed way wrong and the fuel pump was out. Paid the 18 yr old kid $1800 for it. Took 3 days and now she's running tough. But the steering can't turn the tires off road and the box is worn out
uberxj92 is offline
post #5 of 17 Old 10-02-2013, 07:17 AM
TSEJEEPERS
When I first put my Durango box in I was skepticle.
I defently lost some steering radius.
I love it now!
It works awesome offroad.
Even with the front ARB locker locked up it still will turn the Jeep.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 17 Old 10-02-2013, 07:24 AM
blubaru2002
I run the Durango box on my jeep. The turning radius change was somewhat noticeable at first, but not so much anymore. I don't notice a difference at all anymore.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #7 of 17 Old 10-02-2013, 05:48 PM
jjvw
jjvw's Avatar
Can someone explain what the actual benefit is? All I've read about the Durango box is that the steering action is quicker. Is it actually stronger?
I know this won't fit on my '03, but I'm still curious.
2003 Rubicon
jjvw is online now
post #8 of 17 Old 10-02-2013, 06:02 PM
eduardostewart
larger cylinder inside...
post #9 of 17 Old 10-02-2013, 07:51 PM Thread Starter
uberxj92
1992 XJ Cherokee
How much of steering radius is lost? Like does it turn like a Chevy? Lol
uberxj92 is offline
post #10 of 17 Old 10-02-2013, 08:09 PM
eduardostewart
the only thimg i can tell you is that i only have experience from mine. i notice no loss, though i was lucky enough to find info about grinding the bumpstops off the cap and the snap ring in the housing before i took on the rebuild.
i do know there is a difference in turning ratio between the snow plow option and non, though i dint know which is which. sorry not much help but i did what you guys are doing...googling and asking. im sure someone actually knows an cam help you.
if interested i can get all the links i used when i rebuilt mine and what i consider the best threads i found...
post #11 of 17 Old 10-02-2013, 08:46 PM
kjg26
kjg26's Avatar
Please do. Also what did you get yours out of?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #12 of 17 Old 10-02-2013, 08:51 PM
eduardostewart
i cant remember to be honest. i think theres only two years that work from a durango. 97/98 or 98/99...but dont hold me to it
post #13 of 17 Old 10-02-2013, 09:00 PM
kjg26
kjg26's Avatar
Ok. A link to your information would be great
kjg26 is offline
post #14 of 17 Old 10-02-2013, 09:57 PM Thread Starter
uberxj92
1992 XJ Cherokee
Cool I've got a good guy working for me that has one of each box he is gonna tinker with them
uberxj92 is offline
post #15 of 17 Old 10-03-2013, 06:52 AM
eduardostewart
http://www.jeepforum.com/forum/f13/h...-gear-1287129/
http://www.jeepforum.com/forum/f13/h...-gear-1287958/
this vid shows briefly about grinding down the end cap/plug and the internal snap ring you can remove
