#1 | |
Dry Ice in airbox
An old friend of mine told me the other day that when they go wheelin they put dry ice in there airbox (OEM type, obviously not a CAI) and claimed that it helped alot.
Has anyone else heard of this????! Thoughts??? ![]()
#2 |
Dry Ice evaporates into CO2, so no it would not help. It would most liklymake the plasic airbox every brittle and the engine probably would run like **** because it doesnt have the needed oxygen to run.
#3 |
X2 on what comanche said
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] |
#4 |
What did they claim it helped with?
"Our lady of blessed acceleration don't fail me now" |
#5 | |
Think of it this way - you breath oxygen. So does your engine. No oxygen, you die. Same with your engine. Now please ask your friend how breathing CO2 is going to help.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#6 |
I've seen pictures of something similar, where regular ice was placed in a box that was around the air tube(air was NOT drawn directly through the ice, rather, through a tube that was surounded by ice). supposedly it helps to cool the incoming air.
but as others have mentioned, placing dry ice directly in the air box(so that the co2 would be drawn into the engine) is only going to hurt performance.
maroon 1987 Grand Wagoneer. stock for now... |
#7 |
I would have to assume it's only to cool the incoming air, hence, more power. I don't believe the 'melting' dry ice would melt fast enough to choke out the engine. I imagine the cooling effect of the intake air would out weigh the harmful effect of the dry ice co2.
Either way, don't think I'll try it. |
#8 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#9 |
The point of dry ice ::not that I agree with its use:: is to cool the air that flows through. Many local "dragsters" use this. I'd imagine the rate that of melting and producing CO2 would not create any harmful effects to the engine, but I personally would not do this myself. I have seen external slings that strap around smaller airboxes i.e. civic.
[QUOTE=hussler737;8317259] I had a hot girl on facebook say "nice jeep, but i've always wanted a wrangler" and my response was deleting her from my friends list.[/QUOTE] |
#10 | |
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
#11 |
Cold air intake.
The dry ice would work if you packed it around the intake tube. But make sure you have a metal intake tube so the plastic don't break. I'd guess a big enough piece in the air box would prevent the engine from even starting as it will displace the O2. Many folks, including me, have used dry ice in gas tanks to displace the O2 so you can weld on them safer. It works much better than filling the tank with water. You have a hard time getting a good weld with water directly on the otherside of the metal you are welding. On a Jeep the power gain is minimal. On most computer controlled rigs I'd imagine it will take a while for the engine to understand and figure out the new colder air and by the time it does the ice would be melted. Next week we'll discuss giving a cat a dry ice enema. Always exciting!
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#12 | ||
Dry Ice can be used inline with an intercooler, and there are various other designs, this website ARE Cooling (Aluminium Radiators & Engineering P/L) goes over some guys doing it. Has the pro and cons ect so forth. Doubt it do anything put into the airbox, I guess this is another urban legend hah.
06 Red Wrangler X 6 speed hard top Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff. |
#13 | ||
![]() Quote:
#14 | |
#15 |
Believe it or not,DRY ICE,can be used as an explosive device.I once blew a dog house up with a piece know bigger than your thumb.So watch what you are doing.Make sure that everywhere is vented where you use it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
