Driving around the trails in 4 Low. How long is too long?
#1 | |
I tend to keep it in 4 low as soon as my tires get off pavement. I hit long stretches of dirt roads in between climbs/creek crossings and the like. I just hate having to stop before the hairy stuff to put it in 4 low. Will I cause any damage doing this for up to 3 hours a trip?
#2 | |
Re: Driving around the trails in 4 Low. How long is too long?
I have had previous 4x4s in 4Hi for long periods of time as long as the surface I was driving on was not solid enought to eliminate any slippage. I personally would not keep it in 4Hi any longer than necessary, just to be safe!
paulp575 -------- 07 Rubicon Silver AT soft top ===================== Spokane WA ========= Member of: North Idaho Trail Blazers (NITB): http://www.nitrailblazers.org/ |
#3 |
its sucks alot more gas than if you just use 2wd for the easy stuff..
Brad B. "If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick." |
#4 |
with that 4:1 low range, i'd put it back into 4H for the easy stuff.
but no, its not going to hurt anything, you''ll just have sky high rpms
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla, Chicago Electric 10k winch '99 Z28 M6, some goodies '94 'Vette, A4 all stock |
#5 | |
Join a 4x4 Club
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#6 |
Time itself is not a factor but you do not want to run high RPMs or higher gears (3rd or higher) for extended periods of time.
#7 | |
#8 | |
#9 |
seems lazy to me to not wanna shift outta 4 lo...while it can be beneficial to run 3rd gear lo...its not meant to be used for cruising..thats what 2wd or if needed 4 hi is for
#10 |
My Jeep has spent whole weeks in 4-lo. Doesn't hurt anything. If you have the Tera-Low 4:1 kit, then you cannot run above 2500 RPM in 3rd, and you can't use 4th or 5th at all. The planetaries in the 4:1 kit can't take it.
#11 |
You can, I just don't like running my RPM's up that high. It just doesn't feel right.
Blue Jeep Club Member #197 '02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift. '94 ZJ - May it rest in pieces. |
#12 |
and sux down MORE gas....Id rather conserve what I can when out in the middle of nowhere.
#13 | |
Join a 4x4 Club
#14 | |
Resident McGeek
Kyle - I tag stuff® 2000 Jeep XJ - Chopped / Locked Join the XJ Owners Club | Download the iMarn® iPhone App!1997 Jeep XJ - Daily Driver 2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather! Homepage | Jeepspace Group|Twitter!|Facebook |
#15 | |
Join a 4x4 Club
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
