Door handle stuck and won't open. Need help! - JeepForum.com
post #1 of 12 Old 01-11-2008, 08:11 AM Thread Starter
SexySE
I've got a set of full steel doors on my YJ and the outside door handle on the driver's side is stuck in the "open" position. It won't go back flush with the door. The door can't be opened from the outside but can be opened from the inside. Not sure what is going on. Any help is appreciated.
'88 Jeep Wrangler YJ 4.2L 6 cyl Red/Gray soft top/Black hard top 3" Lift on 33s
'01 Nissan Sentra SE 2.0L 4 cyl Inferno/Charcoal Performance Package Dropped on 18s
'66 Ford Mustang Coupe 289 V8 Silver Blue Poly/Blue
SexySE is offline
post #2 of 12 Old 03-06-2008, 01:27 PM
YJGEEWA
Your going to have to tear into that door and either lube up the handle from the inside, or change out the outside handle all together. It happened to me and I had to replace the handle. It's a great way to prove you have patience, Good Luck.
YJGEEWA is offline
post #3 of 12 Old 03-11-2008, 08:56 AM
YJGEEWA
So how did it go did you get it all figured out?
Even a fish wouldn't get into trouble if he kept his mouth shut.
YJGEEWA is offline
post #4 of 12 Old 03-29-2008, 07:10 AM
pumpykins
I have 95 cherokee the divers door is sprung , someone closed with the door lock and now it won't open. any help would be great
pumpykins is offline
post #5 of 12 Old 06-17-2008, 12:28 PM
miked02
I have this same problem. Anyone figure out how to do this?
2002 Wrangler Sport Black
I6 Cyl. 4.0L 5 speed
Rear: Dana44 |3.73:1 Gears| Front: Dana35
Goodyear Wrangler MT/R 32x11.50R15
Mickey Thompson Classic II Rims 15x8
BDS 2" Suspension, 1" Body Lift
miked02 is offline
post #6 of 12 Old 06-22-2008, 10:27 PM
bluesspeed
you guys are going to have to take the inner door panel off and probably even the glass something may just be hung up or something could be broken but u will need to get in there to find out
bluesspeed is offline
post #7 of 12 Old 12-09-2008, 12:21 PM
guitarADDict18
I have had this problem multiple times over the past year. I put new handles on my '92 yj for the third time, and they are already broken again. The problem is simply that the handles wear out. After less than a month of new handles I am already replacing them again. I am beginning to doubt I am installing them correctly, but they work fine once they are on. Anyone know of any installation guides out there?
guitarADDict18 is offline
post #8 of 12 Old 12-20-2008, 06:23 PM
GilaMtnJeep
GilaMtnJeep's Avatar
One thing to be careful of........ If your handles are breaking, especially if it's repeatedly, make sure you grease the latch itself. Have had a similiar problem and after greasing the latch all was good.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #9 of 12 Old 12-20-2008, 08:59 PM
muskegonjohn
Check out:
http://dailydriventj.com/trim_painting.shtml
the author starts out talking about painting the paddles but then describes, very well, how to take the paddles out. The problem is the replacement paddles are cheaply made where the paddle connects to the rod on the inside of the door. I had to reinstall my factory paddles because the replacements kept skipping. The result was an open paddle and no open door.
muskegonjohn is offline
post #10 of 12 Old 12-21-2008, 03:36 PM
1982cj8
You have to make sure the latch mechanism works smoothly and easily. Then you can repair the yj or cj handle by bending the tab back over the lever on the handle, then i welded a rod on the lever so it would not bend back over the other lever, once you get the handle out you will see how it works.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #11 of 12 Old 02-16-2010, 08:29 PM
Jeepin94YJ
Stuck Door
I just got a 94 YJ with full hard doors and they worked fine until I locked the drivers door and now I can't get it back open. I have the soft panel and the small steel panel off the inside of the door and see that all the linkage for both inside and outside handles along with the lock button are still moving but will not disengage around the door pin. I lubed everything up and still nothing, I did notice that the door lock won't turn with the key. Anyone know what happened? I just bought it yesterday.
Jeepin94YJ is offline
post #12 of 12 Old 02-18-2010, 08:50 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I just had this same thing happen to me (YJ full doors). I opened them up and used wd40 on the moving componants and put it back together. They work well for me now.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
Door handle removal nbrege General Jeep & Off-Road Equipment 9 12-20-2010 02:54 PM
Interior door handle BassWrangler Cheap Tricks & Fixes 13 06-13-2009 01:16 AM
HOW to remove and replace door handle volk1 General Jeep & Off-Road Equipment 1 05-09-2008 10:55 PM
YJ Door Handle magsls1 General Jeep & Off-Road Equipment 0 03-04-2006 01:16 PM
Paint on door handle is chipping off babaoriley General Jeep & Off-Road Equipment 4 02-17-2006 11:33 AM
