Do manual winches work? - JeepForum.com
post #1 of 13 Old 08-11-2011, 04:15 PM Thread Starter
Bean1031
Does a manual winch like this one actually work for getting you out? or is it a waste of money?
http://www.harborfreight.com/8000-lb...2-001b2166becc
Bean1031 is offline
post #2 of 13 Old 08-11-2011, 04:24 PM
colojeepguy
1970 CJ5
Yes. Slowly.
And I'd take that 8000 lb rating with a grain of salt...
colojeepguy is offline
post #3 of 13 Old 08-11-2011, 04:28 PM
Roye77
2011 JK Wrangler
They work great but just remember your only workin with 8' of cable and I'm guessing to get the 8000lb rating its double lined so that's only 4' of cable.
"All men are created equal, then a few become firemen." ~Author Unknown
"Volunteer firemen do it for free!" ~Author Unknown
Roye77 is offline
post #4 of 13 Old 08-11-2011, 04:32 PM
hammerz71
yeah they do, when I was a yonker and lived at my grandparents farm, all my grand-dad had was what was then called a "come-a-long" and that's what he used to get anything unstuck, pull chain link fences, hoist things in the air, etc.
They are slow and I'd get a better one than a Harbor Freight deal, but in a pinch, they'll get you unstuck. So will a Hi-Lift jack. Matter of fact I have one of each, although I own three winches, all Warn, if you count the 2000 lb. one on my ATV, but I still use a come-a-long for certain tasks...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #5 of 13 Old 08-11-2011, 04:40 PM
Roye77
2011 JK Wrangler
Ditto, although my handyman jack has been more handy than my come along
Roye77 is offline
post #6 of 13 Old 08-11-2011, 07:25 PM
sbsg2005
They work but I wouldn't try one out for 8000 lbs. I have 2 or 3 of them and the handles are all bent and no longer work. They bent long before the rated capacity unless a 440 weighs in at 8000 lbs.
sbsg2005 is offline
post #7 of 13 Old 08-11-2011, 08:54 PM
gmiller0737
As stated in the above posts they do work but are slow but far better than nothing,But I don't think 1/4" Cable is rated for 8000 lb
gmiller0737 is offline
post #8 of 13 Old 08-11-2011, 09:31 PM
dwilliams35
Yep, you should get a good one if you want to go that direction. That being said, if you get a good one, you're dropping cash that's halfway to a real HF winch..
dwilliams35 is offline
post #9 of 13 Old 08-11-2011, 09:37 PM
TowMaster
Chain fall works much better than come a long
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
post #10 of 13 Old 08-11-2011, 09:41 PM
dwilliams35
Especially if you're needing a good workout. Those things are heavy.
post #11 of 13 Old 08-12-2011, 09:39 AM
Ross
Yes they work, slowly and only a few feet at a time. I used one like this in the past and it works fine, the two big issues for me where:
1. They only pull you a few feet, and then you have to unhook and reset. When you do this you have to find another way to take the tension off the hand winch (come-along in this case) and anchor the vehicle. I used a hi-lift and come along together. Once I maxed one of them I would switch to the other, kind of like leap frog.
2. When you are using a hand winch you are in the "Kill Zone". If something is to snap, slip or break you are caught in the middle of it all.
I used my little hi-lift, come-along set up only a couple times before I decided to buy an actual winch. I felt it was too much work and too dangerous to keep using hand winches.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #12 of 13 Old 08-12-2011, 09:55 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes they work, about the same way a covered wagon would work to get someone out to California. Works but it's a hell of a tough job using either.
Personally, I believe such a tool just gives a false sense of security. I'd save up for a real winch instead.
Getting
Jerry Bransford is offline
post #13 of 13 Old 08-14-2011, 12:13 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I'm a little late to the party on this one... but we discussed this a couple weeks ago and there are a LOT of good responses here:
http://www.jeepforum.com/forum/f27/s...winch-1239248/
~Richard
billzcat1 is offline
Winches kiffer General Jeep & Off-Road Equipment 10 12-20-2010 03:02 PM
Winches...how big to go wcbond4 General Jeep & Off-Road Equipment 13 10-19-2010 12:06 AM
winches msjc24 General Jeep & Off-Road Equipment 4 07-15-2010 06:31 AM
To those with winches... sbulla General Jeep & Off-Road Equipment 48 03-11-2008 03:16 PM
Winches TombRaider General Jeep & Off-Road Equipment 16 05-21-2005 10:08 AM
