Do I really need cv shaft and SYE. - JeepForum.com
post #1 of 8 Old 02-23-2014, 07:29 PM Thread Starter
wranglerjrk09
I have a 2004 X with 3" lift on 33's. So I'm having vibrations in my drive train, and I was wondering if I need the SYE and cv shaft. Or if I can get by with just new upper control arms??
wranglerjrk09 is offline
post #2 of 8 Old 02-23-2014, 07:55 PM
krawler510
T case drop made my tj with 4" lift drive smooth but the u joints in the driveshaft roasted after 10,000 miles.
The smoothness you get from the sye will surprise you.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #3 of 8 Old 02-23-2014, 07:59 PM Thread Starter
wranglerjrk09
Im thinking now it could be bad flywheel?
post #4 of 8 Old 02-23-2014, 10:21 PM
Demp
Flywheel or not, with a standard length TJ 3" of lift is right where you want to consider a SYE. Some people skirt by with Tcase drops (reduces belly clearance) or upper arms, but in the end the SYE will make a world of difference. Of note you will need the upper control arms anyway to get the CV shaft lined up right.
Demp is offline
post #5 of 8 Old 02-24-2014, 06:23 AM Thread Starter
wranglerjrk09
Well I have the SYE and CV shaft on its way, and also control arms.
And gonna get my flywheel checked out
post #6 of 8 Old 02-28-2014, 09:23 AM
dirtroaddesigns
Here is the CV Drive Shaft Pic
dirtroaddesigns is offline
post #7 of 8 Old 02-28-2014, 02:48 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
That's a good call. 3" is right on the border of needing drive line correction or not. You may have been able to get by with a Motor Mount Lift and/or Transfer Case Drop but the SYE/CV Drive Shaft is the right way to do it.. Once you get your pinion angle set correctly you'll be good to go.
What drive shaft are you getting? Make sure you grease the centering ball regularly. It has a flat grease fitting and requires a pointed end on your grease gun to get to it. Good Luck!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #8 of 8 Old 02-28-2014, 02:49 PM Thread Starter
wranglerjrk09
Im gettjng a Tom woods.
