DIY Winch Plate? - JeepForum.com
post #1 of 8 Old 02-01-2008, 08:43 AM Thread Starter
sdlemaster
DIY Winch Plate?
From the winch plate's I am looking at they seem very simple but a bit overpriced for what they are. How hard would it be to fab a simple winch plate up? My dad is a welder and has access to a lot of different machines in a auto manufacturing plant so I really just need a good pattern and to know how thick of steel to use. Any ideas or help is appreciated.
-2002 Wrangler Sport - RE SuperFlex Lift - SYE/CV TW DS - OME LT Shocks - 33" BFG AT's - ARB's Front and Rear w/ 4.56's - 1" BL/MML
sdlemaster is offline
post #2 of 8 Old 02-01-2008, 09:25 AM
Happy Joe
The last one that I fabbed for a CJ (TJs may need more effort) started out life as a large piece of C channel (7 or 8 inch, I believe) measure your winch carefully). Fabrication involved; cutting to length, drilling a few holes and wielding a piece of 1/4 plate one on the forward flange to extend the flange upward for fairlead mounting. Not particularly difficult but it needed the extension flange to give the fairlead good support.
Mounting to the frame was done with some large angle bolted through existing holes (make certain that there is a piece of pipe around the bolts in the frame if you bolt all the way through it to keep the frame from collapsing when the bolts are tightened. Bolts with the nut inside the frame do not need a pipe.
The winch plate from harbor freight is so cheap that it makes the fabrication of one a waste of effort, IMO.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #3 of 8 Old 02-01-2008, 01:27 PM
MoJeeper
2009 JK Wrangler
Here's the one I made, Not for shur on the measurments, but I probably don't have $20 in it.
09 JKU Sahara
MoJeeper is offline
post #4 of 8 Old 02-01-2008, 01:48 PM
Indy
Indy's Avatar
That's 1 pretty factory wrap you've got there
Have you had a chance to put some strain on the mount yet?
I'm the only gay eskimo.
Indy is offline
post #5 of 8 Old 02-01-2008, 03:24 PM
MoJeeper
2009 JK Wrangler
Pulled my Brother out in a Tracked bobcat skid steer. Roughly weighs 13k-14k lb. Granted he wasn't buried, he was just belly hung in a ditch...Worked flawlessly.
09 JKU Sahara
MoJeeper is offline
post #6 of 8 Old 04-04-2008, 10:18 PM
stillen
this is what im looking for........ any dimensions??
94 YJ, 4 squirrels tugging 31's, 5 speed, 2in budget lift.......RHINOed outside and inside......
Wife's rig.... 2012...GC...24x.......blk on blk.....5.7...
05...dodge ram hemi quad 4x4..this thing sucks on fuel
stillen is offline
post #7 of 8 Old 01-14-2009, 07:42 PM
wingshooter2009
yeah man post some dimensions on that thing. it looks great!
./l ,[___],
l---L ()lllllll()-
()_) ()_)--o-)_)
Black Jeep Society member
Eagle Scout Jeeper #1
Mecklenburg Mudders Vice President
wingshooter2009 is offline
post #8 of 8 Old 09-18-2010, 06:11 AM
siyayeer
2015 JK Wrangler
Bump bump... MoJeeper, that's a nice winch plate man. Any dimensions would be appreciated (if you still have the thing that is ). Thanks
2 TJs in 2 countries.. w/ the bigger Jeep in the smaller country. Damn!
siyayeer is offline
Warn Winch and Winch Plate Advice BigGreenTJ27 General Jeep & Off-Road Equipment 4 09-22-2009 01:35 PM
Winch Plate SmokEaterHD General Jeep & Off-Road Equipment 2 01-23-2009 06:56 PM
Winch plate on non winch bumper. Ski01xj Fabrication Shop 6 09-14-2007 08:26 PM
winch plate WAC_Jeeper Fabrication Shop 10 12-11-2004 06:21 PM
93 YJ Winch Plate jeeptuff General Jeep & Off-Road Equipment 2 03-18-2001 04:20 AM
