DIY Instant Trunk-YJ - JeepForum.com
post #1 of 9 Old 06-10-2014, 06:45 PM Thread Starter
Bobby_S
Hi everyone,
I don't write a lot on here but I thought this was a helpful thing for other people on this forum.
I made a DIY instant trunk for my YJ. I started with a metal shelf that was 30"x35.5". Since the shelf was already the size of the trunk, I didn't really have to cut much off of it to make it fit. After all the cutting was done, I went to Home Depot and got 4 gate latches. I welded these to the shelf in the predetermined places. After all the welding was done, I test fitted the shelf in the back of the Jeep. Then, I marked the outline of the lock on the tailgate to be cut out of the shelf.
Afterward, I marked where the latch pins would go into the tub and drilled corresponding holes.
This is what the shelf looks like when everything is cut and drilled. It still needs to be painted though. And don't mind my welds, I'm still new to welding.
This is the front left latch:
This is the front right latch:
This is the back right latch:
And finally, the back left latch:
This is the bottom of the shelf, the back 2 latches can stay in the tub and the shelf can be pivoted up like in this picture:
This is what the bottom looks like when all the latches are out and the shelf is down:
This is the top of the shelf:
Here is underneath the shelf with my toolbox and ammo box under it:
Bobby_S is offline
post #2 of 9 Old 06-11-2014, 05:20 PM
kjg26
kjg26's Avatar
Love the idea, how much does it rattle?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #3 of 9 Old 06-11-2014, 07:32 PM Thread Starter
Bobby_S
Surprising, even with bare metal on metal, it doesn't rattle that much at all, even offroad
"Try driving through it backwards to reverse the issue" -gregstudeny
Bobby_S is offline
post #4 of 9 Old 06-11-2014, 08:43 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Great idea. The only thing I would have done differently would have been to use these spring latches instead of the gate latch
http://www.amazon.com/Locked-Spring-...6WZNZ10PXKA1RE
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #5 of 9 Old 06-11-2014, 09:03 PM Thread Starter
Bobby_S
Those spring latches would be cool to have because they would make putting the shelf in much easier. When I was still thinking about how i was going to make the shelf, the idea of using some c-channel, eyebolts, and a spring crossed my mind. It would have ended up being the same thing as those spring latches but with a hole in the end to grab rather than a t-handle
Bobby_S is offline
post #6 of 9 Old 06-12-2014, 01:11 AM
schitzangiggles
King of Macastan
The five pack is @ $7 on amazon prime...
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #7 of 9 Old 06-12-2014, 07:27 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Very nice. I had something similar in my old scout in the form of a wooden box built level with the fender wells. This works better since it traps everything under it, keeping that stuff from landing in your lap if something goes bad.
I would recommend a bushing in the fenderwell. The vertical pounding of the gate latch in the thin steel of the fender will begin to egg it out. Something like a door hinge bushing, sheet rock anchor, or a piece of steel tubing welded to a mounting flange would do the trick.
http://www.amazonsupply.com/miniatur.../dp/B0045E0EEO
Or the cheap plumbing alternative.
or the cheap plumbing alternate
jeepdaddy2000 is offline
post #8 of 9 Old 06-12-2014, 07:32 AM Thread Starter
Bobby_S
Jeepdaddy, the bushings are a really good idea. Only thing Is that they would have to go on the backside of the fender, to keep the gate flush
Bobby_S is offline
post #9 of 9 Old 06-12-2014, 09:33 AM
schitzangiggles
King of Macastan
You can also weld a grade 8 fender washer to the sheet metal.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
