Quantcast Discussion on Lift Installation Tips - Page 5 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Discussion on Lift Installation Tips
Old 08-21-2006, 09:21 AM   #61
redrock4x4
Originally Posted by smurison14
YOU NEED a spring compressor
No you don't. They can be extremely dangerous, and they are completely unnecessary. I would not recommend them due to the potential safety concerns, and they're certainly not required by any means.
We install coils up to RE 5.5"s, which really net closer to 7" of lift, w/o spring compressors w/o any problems.
redrock4x4 is offline   Reply With Quote
Old 08-22-2006, 12:14 AM   #62
smurison14
how do you do that? we could barely get 3" springs in when they are compressed and someone is stepping on the axle. Unless you disconnected all the brake lines and control arms and dropped the axle on the ground that would be the only other way i guess.
smurison14 is offline   Reply With Quote
Old 08-23-2006, 06:32 PM   #63
redrock4x4
I suppose stock control arms could present a problem for 3"+ coils, but we generally don't recommend nor install 3"+ lifts w/ stock control arms or stock brake lines. Most of our 3"+ kits include offset control arms and/or long arms which will allow for enough droop to get the coils in and out. If your control arms are binding to the point that you can't install the coil springs w/o really compressing them, that alone should indicate there's a problem. Most shocks for lifted applications will allow the axles to droop far enough that the springs will unseat a little, or they will at least reach their fully uncompressed length. If your control arms are limiting your flex before the shocks max out, that's something that should be addressed in my opinion, as that will put more stress on your control arms and brackets than there should be.
Either way I would much sooner unbolt the stock control arms, and/or track bars than use spring compressors. I have used compressors in the past, and I've also had one let go, and it's not a fun thing. We avoid them at all costs now. It doesn't take long to unbolt the arms and bolt them back up, and it's MUCH safer.
With that said if I'm lazy or in a hurry and I can't get a coil in all the way there are a few tricks. First of all remove the bump stops if you haven't already and the cups, hold them inside the spring when installing, and then bolt them back up once the coil is installed. That alone gives you quite a bit of room. If that's not enough, have someone stand on the end of the axle and watch your fingers. If that's still not enough, take a breaker bar and put it between the coil and the lower spring perch. If you do it just right, you can lift up on the breaker bar and the coil spring will compress and slide into position at the same time.
Old 08-23-2006, 11:44 PM   #64
smurison14
Yea i agree the stock control arms were the limiting factor, but this was my first lift and i couldnt afford the new control arms. Hopefully i can get my currie j arms on with little effort. the rear coils we needed the compressor, but on the fronts we could have done without. live and learn. thanks
Old 09-18-2006, 09:41 PM   #65
VTECZILLA
Originally Posted by 93jeepyj2.5
My suggestion is, DON'T lay under the spring while unbolting it......I learned the hard way and had a bruise on my chest for about 1 month.
-Heath
2003 Sahara [B]4" Superlift JKS 1.25BL and MML 33" BF-G muds on
American Racing Baja's Magnaflow exhaust. Factory Rubicon Rockers. 10K winch.
VTECZILLA is offline   Reply With Quote
Old 08-16-2007, 04:37 PM   #66
enochstek
New Jeep Lift Kit Website
http://www.rcjeepliftkits.com
Check it out!
enochstek is offline   Reply With Quote
Old 12-02-2007, 08:19 PM   #67
OkieEagle
Performed a 4" Superlift Superride lift on my '06 Golden Eagle this weekend. No spring compressor. But it don't hurt to have a friend with a huge two bay shop, lift and the miracle tool...a hydralic tranmission lift. We had the jeep head high all weekend and used the transmission jack to support or compress everything. It was a Godsend!
Also air tools are handy. Pitman Arm pullers are nice to have ready.
The genius that writes up the instructions stating it's a four to six hour job with basic tools is on crack! I don't claim to be a NASCAR pit crew but two of us spent about 10-12 hours on my Jeep and the partner is a full time mechanic.
2006 Jeep Sport Golden Eagle...Superlift 4" Superride Suspension Lift, Superride Adjustable track bars front and rear, OME steering stabilizer, Olympic Dave's Rack, Olympic Rock Bumpers front and rear, Olympic Rectangular Nerf Bars, Olympic sierra rack, Airaid CAD Intake and throttle body spacer, Garmin GPS system, Sirius Radio, KC Hilites(6 driving lights/2 fog).
BF Goodrich 33/12.50/15 MT's on Richard Cepek DC-1 Black polished.
OkieEagle is offline   Reply With Quote
Old 12-16-2007, 10:18 AM   #68
JeeperStitch
X2. Took me and 2 buddies who are full and part time mechanics respectively 10.5 hours to put on my 3" Full Traction Eco. Kit.... still haven't done the t-case drop either
-"Stitch"
"We have no problems that cannot be solved by the judicious application of dynamite."
99 TJ SE -- 2.5L 4-banger, 3" Full Traction Economy Suspension lift, Stock everything else... for now
JeeperStitch is offline   Reply With Quote
Old 04-27-2008, 01:36 AM   #69
ImportEater
Lots of awesome info so far everyone.
I have a 94 YJ and am thinking about this,http://www.rcjeepliftkits.com/products/YJ/Jeep_YJ_4in_lift_kit.html as a fathers day gift to myself from the family. Id like to run with 35" rubbers and wheel semi hard.
The questions I have about this lift are:
Is it easier to drop the transfer case or put on a SYE? The parts Im alittle usure about are the driving linkage and transfer case. I think I can do the lift but I dont think I have the experiance to do the SYE or sterring system if any needed to be done.
Will the brake lines need to be replaced or reloctaed with this system either? I am thinking fo a 1" body lift aswell, the body mounts know are shot so I figure may as well get them.
I have trusty 17" jack stands and a garage. I can get some air tools and impact wrench. I got the list of tools and stuff recommended in this thread, but is there anything else I should be thinking about doing or buying?
Thanks in advance.
ImportEater is offline   Reply With Quote
Old 04-27-2008, 08:15 PM   #70
john NC
if you have an 03-06 tj with an auto (42rle), it's a lot easier to get front springs on if you unbolt the stock transmission skid from the frame so that it hangs down. that way it doesn't rub on the driveshaft when you jack up the rotors to get the new springs in/out
it took me a little while to figure that out and not in any of the write-ups since most of those are on older tjs (i've since replaced it with a skid row skid).
and a breaker bar is probably one of the most commonly used tools in my box, it works much better for getting bolts off than a socket wrench. box wrenches are also much easier to use than a crescent wrench for holding nuts still (especially control arms, that 21mm one was worth every penny after trying to get a control arm bolt back on by myself with an adjustable wrench)
john NC is offline   Reply With Quote
Old 04-28-2008, 02:37 PM   #71
Silver04TJ
Just finished up putting on an RE 3.5 standard kit.
Suggestions:
1. PB BLASTER ... this stuff makes things a LOT easier!!
2. Factory shocks can be a PITA to get off. We had to take a 4" grinder and square off the shaft of the shock and put a wrench on it to turn the nut off the top which wound up breaking on both front shocks.
3. TALL jackstands
4. Estimate the amount of money you will spend on the lift and tires etc and add about $300-800 or more.
5. An extra set of hands helps immensely!
6. Read everything you can on installs, suggestions, and ask loads of questions on jeepforum.com.
7. In my experience putting on this lift.. what I thought would be easy was hard and what I thought would be hard was easy.
Finally... just get your hands dirty, do it yourself, save money on the installation, and you'll feel great that you did it yourself.!!
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline   Reply With Quote
Old 06-19-2008, 03:03 PM   #72
rrisher
1987 YJ Wrangler
Suggestions:
3. TALL jackstands
I'm going to tackle it myself this next week so, wish me luck. I've done just that, reading up everything I can on installing YJ lifts.
rrisher is offline   Reply With Quote
Old 07-03-2008, 12:28 PM   #73
rrisher
1987 YJ Wrangler
Does anyone know the torque requiremnet on the shacke? Is it 75 or 90 lbs?
They are just stock M.O.R.E. shackles.
Old 08-20-2008, 11:54 AM   #74
xjmallcrawler
i just installed a 4.5 aal rough country on my xj and man was it easy ... well other than the shakle bolts front end took me about 2 hours to complete. the enclosed directions were simple to follow.
xjmallcrawler is offline   Reply With Quote
Old 08-22-2008, 03:48 PM   #75
LoCo_ZJ
I am getting ready to install a 3" Skyjacker on my ZJ. I should have no problems getting the new coils and shocks in place right? I'm also installing 2" coil spacers, new lower control arms, a steering stabilizer, and installing replacement (longer) track bars. Anything in particular i might need or should watch out for?
p.s. The 2 friends that are helping me are both certified Crysler mechanics from the local jeep dealership so i've already got that covered.
LoCo_ZJ is offline   Reply With Quote
Glock Forum
