Discussion on Lift Installation Tips
#46 | |
how much is lobor for an install of a lift
#47 | |
supaJEEP
if it wasn't my daily driver, I'd find a way to do it myself
Haik Muddin' Videos -SOLD- White Jeep Club Member #8675309 Rubicon Express 5.5" Long Arm Lift Kit - Advance Adapters SYE w/ Custom driveshaft 35" SuperSwamper Boggers - SMF rear bumper w/ swingout tire carrier Cobra 75 WX ST - Firestick II 5' - PIAA 520 - PIAA 525 - 488 Gears - Detroit Locker SMF front bumper w/ bull bar - Warn 9500ti winch |
#48 | |
#49 | |
supaJEEP
And yea, I'm in Canada, for us a lift is a couple bucks more than what you'd pay in the states. ... sucks but what can ya do?
#50 |
Sorry you didn't say what kind of jeep it was or what kind on lift, but for $1,600 I think I could do it myself or find someone who has to lend a hand. Good luck.
#51 |
with a 4 inch suspension lift and a 2 inch body lift and a shackle lift, what else would be involved to make it all work. Brake line lengths, drivetrain lengthening, gearing etc?
#52 |
can i rent jackstands at any hardware store like home depot or do they only have them in auto parts stores. also, do they rent floor jacks? one more thing. when you intalled the lift, did you have to take it to the off road shop to get it aligned and checked out?
#53 |
Here's some good tips/notes we've pieced together over the years:
http://redrock4x4.com/tech/rr_install_notes.pdf |
#54 |
i've got a question. i'm trying to put on new shackles and the spring doesn't want to line up straight with the shackle. the shackle end swings out to the side. any ideas on how to align the spring up to i can bolt on the new shackles?
"Flying is learning how to throw yourself at the ground and miss." - Douglas Adams You laugh because I'm different. I laugh because I just farted. "The box said 'Required Windows 95 or better'. So, I installed LINUX." |
#55 |
Have a buddy that's a mechanic at a dealership and has free use of the shop on Saturdays
Those big lifts and air tools really make things easier. And we didn't need spring compressors.
03 Rubicon RE 3.5" and 1.25" JKS BL 285/75/16 Kumho MT's |
#56 |
Don't know if it was said... but if you have the little clips between the axle and shackle to keep the springs together...makes sure you point the bolt towards the center of the vehicle.
I bought a Jeep with a lift on it and someone left a bolt with threads sticking out, and it chewed the hell out of hte tire...
'93 Wrangler...close to stock... |
#57 |
Just finished my lift.
Please, do yourself a favor. TAKE YOUR TIME. My buddy and I must have wasted THREE hours backtracking on 2 big mistakes we made (Trac bar bracket and forgetting a bump stop)
See it is I who created the blacksmith who fans the coals into flame and forges a weapon fit for its work. And it is I who created the destroyer to wreak havoc; No weapon forged against you will prevail, and you will refute every tongue that accuses you. This is the heritage of the servants of the Lord and this is their vindication from me." says the Lord. -Isaiah 54:16-17 |
#58 |
I just wrapped up my RE 2.5" lift on my 93 YJ. What an adventure. Having a friend to help is a big PLUS. I live in AZ so rust was not a problem, in fact every single bolt came off with little persuasion. I don't have air tools but I do have an electric rattle gun. That thing helped tremendously.
A couple of things... Remember that parking/emergency brake line. You might have to re-route it so you don't pull it out by the roots when you articulate down. On the front don't forget your vacume lines to the front differential. I had to re route those also. When installing boomerang style rear shackles from the RE kit make sure the knee of the boomerang is pointing forward... we got to do that one twice. ![]() If you do not have a garage try the back patio. Mom did not like it at first, then she came out and saw the jeep half lifted. She liked it after that. ![]() TRY NOT TO LAY UNDER THE JEEP. If at all possible work from the sides and not under it. I don't trust anything to hold that jeep up except its own tires. When you are working with the little tiny brake line connectors use a small hammer to bang the wrenches, don't try and muscle it... you might round it off. (not speaking from experience or anything) Most off all, HAVE FUN, drink a beer. Kick back. YOUR LIFTING YOUR JEEP. |
#59 |
If you are installing a SYE, do yourself a favor and have a new speedo gear o-ring ready. The old one will probably be damaged and will not seal properly.
#60 |
I recently installed a 3" teraflex on my 02 TJ with my dad and uncle at my uncles house. We had an air compressor so we could impact the lugs and other nuts on. That saved us a lot of time. YOU NEED a spring compressor. cinching them down with the impact is even faster. When you install the coils step on the axle to droop it. that helps. take your time on the rear upper shock mounts, we stripped one out and had to get another. We werent working that hard, and it took us around 6.5 hours with many breaks in-between. On a TJ dont bother with the drop pitman arm, it would screw your front end up horribly. I got quoted 650 by a shop, which was more than the lift. the guy said he shot a coil spring by accident so i really didnt want him wrenchin on my TJ.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
