Differential problems - JeepForum.com
post #1 of 6 Old 02-04-2012, 01:28 PM Thread Starter
mitch23
Hi you guys, I am new to the forum. I own a 2000 Grand Cherokee Laredo V6 with 140,000 miles on it. It had always been a good/reliable vehicle without any mechanical failures ....until now.
I had recently noticed a high pitch whine with acceleration. Took it to my mechanic (has always been very reliable in the past, not the cheapest but does quality work) who popped open the diff. and basically told me everything was shot, everything even down to the carrier. The car has a Dana 44 diff. in it which from what he told me, are notorious for these problems. I have been quoted $1800 for parts and labor, which I think have a 100,000 mile warranty.
Is this reasonable? I know, I could go the used parts route, but I would rather nip it in the bud and not risk it happening again in 6-12 months. Thoughts?
mitch23 is offline
post #2 of 6 Old 02-04-2012, 01:42 PM
ZEEROX1TJ
Goto junkyard find new axles there. They should bolt right on. Way cheaper.
ZEEROX1TJ is offline
post #3 of 6 Old 02-05-2012, 07:23 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
First of all, front diff or rear diff? If rear diff, 2WD or 4WD? The Dana 44a is very uncommon in inline-6 Grand Cherokees, only found in *some* of the I6s with tow package, and I6 models with QuadraDrive (or the very uncommon SelecTrac w/ special-order rear LSD).
The aluminum Dana 44 in the WJs aren't awful but they do tend to have some case flex issues that can lead to bearing failure and/or abnormal R&P wear.
$1800 is a LOT of money for a vehicle that is only worth $6k on a good day. I would go used. www.car-part.com to find an axle. Also, be sure to visit us over in the WJ forum, http://www.jeepforum.com/forum/f310/ - we can help you with DIY repairs, maintenance, modifications.
~Richard
billzcat1 is offline
post #4 of 6 Old 02-05-2012, 07:42 PM
AKGeo
Take a picture of the innards so an impartial third party can tell you what's what. I'd be very surprised if a carrier was "shot", especially if all you have is a whine. Sounds like just a bearing...they're probably going to replace the pinion bearing and pocket the rest.
AKGeo is offline
post #5 of 6 Old 11-17-2015, 04:03 PM
denverdog
TJ Differential Problem
I was driving my TJ Jeep Wrangler and I heard a small noise at it stopped. I put it in neutral and the drive shaft just spins on the differential with no resistance What would cause that in the rear end.
D. Sullivan klamathglenn@MSN.COM
denverdog is offline
post #6 of 6 Old 11-18-2015, 08:55 PM
TSEJEEPERS
denverdog please start your own thread.
You will get a lot more responses.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
dana 44 , differential
differential oil help please bergar65 Engines & Drivetrain 2 10-31-2011 09:11 AM
differential oil.... bergar65 Tires & Wheels 0 10-28-2011 05:11 PM
Differential Help Bobbis Engines & Drivetrain 1 12-11-2010 02:27 AM
HOT differential?? bvectra Engines & Drivetrain 0 01-06-2010 03:36 PM
Did my Differential go out? Samgler Engines & Drivetrain 2 12-09-2007 11:07 AM
