differential fill plug stuck - JeepForum.com
post #1 of 31 Old 10-18-2009, 11:25 AM Thread Starter
purplepig
i cant get the rear plug out. i dont want to strip it. any ideas???
purplepig is offline
post #2 of 31 Old 10-18-2009, 11:31 AM
XJMuscle98
PB Blaster
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #3 of 31 Old 10-18-2009, 12:43 PM
flatlander757
If it's off the vehicle, heat up the cover around the plug. If it's on the vehicle, I don't know if that will cause any ill effects to the RTV sealant or any fluid that may be directly on the inside of the cover.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #4 of 31 Old 10-18-2009, 12:52 PM Thread Starter
purplepig
i tried wd-40 with no luck and i thought about heating it but i dont have a blow torch. yes, it is still on the vehicle.
post #5 of 31 Old 10-18-2009, 01:13 PM
XJMuscle98
wd40 is a lubricate not a penetrating oil which is what you need.
Ronald Reagan
Currently: 10
post #6 of 31 Old 10-18-2009, 01:22 PM
flatlander757
WD-40 is NOT a lubricant... it just displaces water.
Currently Jeepless.
post #7 of 31 Old 10-18-2009, 01:33 PM Thread Starter
purplepig
thanks will try something else
post #8 of 31 Old 10-18-2009, 04:54 PM
wushaw
Rockin jeep
wushaw's Avatar
Impact wrench.
wushaw is offline
post #9 of 31 Old 10-20-2009, 10:20 AM
cidd
Depends on what rearend you have ??
cidd is offline
post #10 of 31 Old 10-20-2009, 04:59 PM Thread Starter
purplepig
i think it is a dana 35. 2000 wrangler 4.0
post #11 of 31 Old 10-20-2009, 05:37 PM
XJMuscle98
Originally Posted by wushaw View Post
Impact wrench.
On an aluminum cover?
bad idea.
Ronald Reagan
Currently: 10
post #12 of 31 Old 10-20-2009, 06:22 PM
05RedRME
Is it alright to use anti-seize on the plug threads when you re-install it?
05RedRME is offline
post #13 of 31 Old 10-20-2009, 06:58 PM
flatlander757
If you're worried about stripping it you definitely don't have a D35(unless the cover is aftermarket)... D35 has a rubber fill plug... the D44 has the thread-in fill plug that takes a 3/8" square to unthread.
bad idea.
Unless it's aftermarket it most definitely isn't aluminum. It should be stamped steel... Aluminum doesn't rust.
I've never heard of doing that, I would personally just -lightly- smear the threads of the plug w/ RTV when you go to reinstall it. It's pipe thread.. it seals with thread interference.
Currently Jeepless.
post #14 of 31 Old 10-20-2009, 07:38 PM
YJake
The d35 has a rubber plug, just changed my diff fluid a few days ago.
Although I do think a regular threaded bolt would have been much better. Tired of it leaking so I RTV'd it on the last time.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #15 of 31 Old 10-20-2009, 07:54 PM Thread Starter
purplepig
really? my socket wrench fits the hole perfectly. it just doesn't turn. i tried the pb blaster too as suggested. does the rubber plug have a hole in it?
where is the fill plug? mlombardi Engines & Drivetrain 2 05-03-2009 02:49 PM
8.8 oil capacity and SOLID fill plug size chadsmeltzer Engines & Drivetrain 2 02-07-2009 10:22 AM
NP 231 Fill Plug ? Skeezer Engines & Drivetrain 1 03-12-2008 09:23 AM
Leaking Differential Fill Plug sb127 Engines & Drivetrain 5 06-01-2007 06:21 PM
fill plug 83 cj-7 258 General Jeep & Off-Road Equipment 4 05-11-2004 09:39 AM
