Detroit TrueTrac on Jeep WJ with Quadra Drive - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Detroit TrueTrac on Jeep WJ with Quadra Drive
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 08-26-2005, 02:27 PM   #1
chieeeeef
Hello All... I'm a rookie at this so bear with me....
I have a 1999 Jeep WJ with DANA 30 3:73 gears up front. My Vari-Lok differential went bad (grinding, sticking) so I decided I would swap it for a Detroit TrueTrac. Purchased TrueTrac from Summit Racing (part # 912A314), dismantled the front end and placed the TrueTrac (that was the easy part). When I tried to install the stock axle the driver side was short and the passenger side won't go all the way in. I had the impression that the TrueTrac is a direct swap for the Vari-Lok and the stock axle should plug in. It wasn't the case. After a while I got frustrated so I returned the TrueTrac and purchased a Vari-Lok stock replacement. My question to all you experts is, did I need to get after market axles to make the TrueTrac work with my QuadraDrive?
Question 2: On the Vari-Lok Differential, is the plenum a vital part for the Vari-Lok to function?. It seem to me that for $130.00 for a piece of metal shielding is a bit too expensive.
chieeeeef is offline   Reply With Quote
Unread 08-27-2014, 07:19 PM   #2
bwiygul
bump!! i'm in the same boat!!
bwiygul is offline   Reply With Quote
Unread Yesterday, 03:20 PM   #3
rjbruzan
I would give Randys Ring and pinion or one of the others a call. Its a shame the True Trac was not able to work as its a great unit. I had one in my old XJ and loved it. Did you try putting the axles in after you removed the TrueTrac?
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is online now   Reply With Quote
