Detroit E-Z Locker, Dana 30 Front - JeepForum.com
post #1 of 4 Old 03-04-2006, 07:02 AM Thread Starter
towerassoc
towerassoc's Avatar
Location: Prescott,AZ Summer, Sun City West, AZ winter.
Would like to hear any good or bad advice on the Detroit E-Z Locker for the Dana 30 in the front. I would like to install this but have no info on performace.
Thanks
Bill
2004 RMA, Auto,4.0,RE SF 3.5, Dana 44 rear 30 front, 33x12.5x15 BFG AT, SYE TW DS, OME Shock, OF Fab Tire/can holder.
towerassoc is offline
post #2 of 4 Old 03-04-2006, 10:30 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
just a bump i to am curious, how does it compare to a lock-rite
RnEmOvr is offline
post #3 of 4 Old 03-04-2006, 12:07 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
EZ Locker and a Lockrite are basically the same thing...
Detroit makes one and Powertrax makes the other...
they're both "invisible" in the D30 in 2HI, and perform the same in 4HI or 4LO...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 4 Old 03-04-2006, 11:04 PM
Lcars
Nanners...MMMM..Toasty
Lcars's Avatar
Mine is not invisible on the front. Since there is no hub locks in the front, the axle turns. You will notice some pull and an occasional bang from the front in 2HI. It is drivable as a daily driver. Just every now and then they will unload with a bang on the street.
When in 4X don't plan on turning very well. You will be able to climb anything straight up but I found out that if you are in deep sand and want to turn at any speed, you just keep on going straight up and over. - Learned that the hard way.
I am going to remove mine and go to a selectable locker, either air or electric, in the front so I can unlock them when I need to in 4X.
Installation was fairly easy and can be done in a driveway without having to reset up the gears.
<--- I got a big Dancin Nanner
- Jeep Encyclopedia
Originally Posted by JungleLarry
THAT'S MY DICK IN YOUR B*TT!
(Edited for content.)
N7GTJ
View my Paddock Pool construction nightmare at
Lcars is offline
Aussie front locker on dana 30 questions Jenyus425 Engines & Drivetrain 4 10-21-2008 03:51 PM
aussie vs detroit ez locker for the front axle gribbles Engines & Drivetrain 2 06-06-2008 10:20 AM
Detroit autolocker in front dana 30--- 35"s with a 33" spare ok? Blk2kTj Engines & Drivetrain 9 02-27-2007 08:50 PM
Detroit locker in front? And regear? tcourdin General Jeep & Off-Road Equipment 7 07-09-2005 10:00 AM
Detroit EZ Locker ?? kg6mti General Jeep & Off-Road Equipment 0 11-22-2004 11:04 PM
