Determining gear ratio question - JeepForum.com
post #1 of 5 Old 09-10-2001, 08:15 PM Thread Starter
offctr
How can I determine the gear ratio of an axle already out of the vehicle --no tags --dont want to start pulling the cover --etc fromthe revolutions of the yoke to the wheel
1 to 3/4 or wheel to yoke 1 to 1-1/2 can I calcualate the ratio if known to be within 3.07 to 4.88 range ????
2001 Cherokee limited 94 Cherokee country 93 Wrangler
My former jeep's - 84 CJ7 great trail rig ,79 Cherokee Chief S,75 CJ5 golden eagle W/a 350 in it
offctr is offline
post #2 of 5 Old 09-27-2001, 01:03 PM
BaileyTJ
if you know what truck it is out of you can try www.ring-pinion.com and click on gear calculator
HTH
"If you don't plan, you plan for failure"
BaileyTJ is offline
post #3 of 5 Old 10-02-2001, 07:40 PM
RodeoRob
RodeoRob's Avatar
you can get a rough idea... jack up the car, spin the wheel one complete revolution and count how many rev's the driveshaft makes. for example, if you driveshaft spins 3 times for 1 turn of the wheel, you most likely have a 3.07 or something in that ballpark.
To be more exact, what you need to do is open the diff cover, count the teeth on the ring gear and count the teeth on the pinion, and divide the two numbers. there's your ratio.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 5 Old 10-03-2001, 04:19 PM
Willis91YJ
The axle ID number as well as the gear ratio should be stamped on the back side or the right tube. Look for a set of factory stamped numbers, the feds require them to be there before it leaves the factory, you may have to clean-off a few layers of grime to find'em but they're there!
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
post #5 of 5 Old 10-03-2001, 06:35 PM
mytjnamedrex
I tried the lift up tire and spin thing and it came out 1:1. I know this isnt possible so is there a trick? I put the car in N and my friend and i slowly spun the rear wheels in the same direction....everything was marked and i got 1:1. Its got 30" tires if that makes any difference.
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
Which gear ratio? slowTJ88 Engines & Drivetrain 1 06-02-2007 04:14 PM
rear end gear ratio question amethystrose Engines & Drivetrain 2 10-17-2006 06:49 AM
Gear ratio question zaq123 Engines & Drivetrain 0 03-15-2006 04:58 AM
Lift/Gear Ratio/Tire Size Question FLCJ7 Tires & Wheels 0 05-24-2005 05:43 PM
winch gear reduction ratio question (quick reply please) we3jeepers General Jeep & Off-Road Equipment 3 10-31-2004 03:01 PM
