Death wobble around 35 mph - JeepForum.com
 1Likes
  • 1 Post By MDTJ
post #1 of 14 Old 08-18-2017, 11:34 AM Thread Starter
Indiethejeep
Im experiencing death wobble around 35-40mph on my 2004 Jeep Wrangler Sport. Once I get past that speed the Jeep is fine or I've also notice sometimes if I gently turn my wheel from side to side while going through that speed it won't be as extreme. Some days it doesn't do it and others it's really bad. I've had this problem about 5 months and I exchanged my ball joints and hubs which fixed the problem. I know my pinion yoke is pretty bad and I've ordered a new part to replace it. Could that be my problem? If anyone could give me tips on what I should look at or fix on my Jeep that will be greatly appreciated. Thank you!
Indiethejeep is offline
post #2 of 14 Old 08-18-2017, 11:57 AM
222Doc
222Doc's Avatar
tire balance is what starts the issue. over time the slightest off balance works against the components. they wear out. after the bjs and what ever was done did you have the tires checked? if not then the cycle has started over again. things like track bar bushings, MAY be the issue now. But all these parts can be checked and dont go down the pic part replace it till you find a issue. BUT tires are very important in this picture.
222Doc is offline
post #3 of 14 Old 08-18-2017, 02:01 PM
MDTJ
MDTJ's Avatar
I don't think you have death wobble. I've never experienced or heard of a death wobble that is solved by speeding up. What you have is a speed triggered wobble most likely due to tire balance. Have a good shop put detailed care into balancing your front tires and see if that solves it.
Read this: http://www.jeepforum.com/forum/f9/di...rsion-2359089/
Also, welcome to the forum. Please fill out your profile so we can help better in the future.
Jerry Bransford likes this.
Good resources:
MDTJ is offline
post #4 of 14 Old 08-18-2017, 02:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by MDTJ View Post
I don't think you have death wobble. I've never experienced or heard of a death wobble that is solved by speeding up. What you have is a speed triggered wobble mostly likely due to tire balance. Have a good shop but detailed care into balancing your front tires and see if that solves it.
Exactly, it sounds like you are experiencing a shimmy, not Death Wobble. True fully developed Death Wobble is VIOLENT, beyond what anyone can comprehend until they've experienced it. And the last thing that can be done during DW is to speed up, the only thing you can do to stop DW is to slow down to the point you're nearly stopped.
Speed sensitive shimmies are nearly always from nothing more than an imperfect tire/wheel balance, sometimes coupled with something in the front-end being loose like the track bar.
Jerry Bransford is offline
post #5 of 14 Old 08-19-2017, 08:13 AM
biffgnar
biffgnar's Avatar
I think DW actually can be resolved by speeding up, but very few people have the guts to do it. I do though agree in this case it doesn't sound like OP has DW.
And DW can be speed specific IMO. Didn't Blaine once upon a time try to do some sampling to figure out whether the speed it was triggered at was indicative of where the problem was coming from? Along these lines 35 MPH is slow for DW to kick in. If it really were DW kicking in that slow I would think should be something obviously very wrong /loose.
biffgnar is offline
post #6 of 14 Old 08-19-2017, 11:29 AM
MDTJ
MDTJ's Avatar
I don't have those guts! Also, think about the damage that could be done if speeding up intensifies it.
My Jeep has had DW on two separate front ends for two separate reasons. Both times it would trigger around 35-40.
Good resources:
MDTJ is offline
post #7 of 14 Old 08-20-2017, 06:46 AM
wilson1010
Don't believe it. I've had a lot of actual death wobble and anyone who would try to speed up is either a moron or on drugs. If someone has a video, let's see it. Probably a video of shimmy not DW.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #8 of 14 Old 08-20-2017, 06:25 PM
Jerry Bransford
Administrator
Having had fully developed and EXTREMELY VIOLENT death wobble, I wouldn't even consider speeding up. I can't imagine anyone who has had DW as violent as I have experienced would consider speeding up an option.
post #9 of 14 Old 08-20-2017, 08:21 PM
biffgnar
biffgnar's Avatar
I think Blaine has talked about doing it, but doesn't recommend it to anyone.
biffgnar is offline
post #10 of 14 Old 08-21-2017, 12:12 AM
wilson1010
My niece, MIT MEng '04, who does not drive, and only heard of death wobble Sunday, from me, asks if anyone has ever tried a big air shock on one side but not on the other, or vastly different coil spring tensions to prevent the harmonic effect.
Shall I tell her to stick to ironing her husband's shirts (actually she works for an Rx company), or does she have a valid thought?
post #11 of 14 Old 08-21-2017, 12:49 AM
Pistolpete926
Ive had the dw in my zj and it totally felt like each tire was lifting off the ground. But after experimenting with it a bit due to lack of funds. Speeding up helped occasionally but most times it just tamed the wobble and started back up after letting off the accelerator. But i replaces my most worn bj and the tenstion shock. And it stopped. Shortly after for the rest of the bj' s sake replaced all upper and lower bj's in the front. Bj' s are cheap and easy fix' s and most times are the problem
Pistolpete926 is offline
post #12 of 14 Old 08-21-2017, 10:07 AM
Fourtrail
1974 CJ6
You can accelerate through the start of death wobble. I had it that would start at a certain speed, but if I stood on the go pedal hard, it would change suspension/steering geometry just enough that I could pass the harmonic speed that would start the death wobble. I will agree though that once it sets in, the only way to stop it is to come to an almost complete stop.
As to an air shock or different coil rate, I can see that masking the issue as it could just slightly change the geometry enough and may get you past the harmonic speed. I 'fixed' mine by adding hydro assist as it keeps the harmonic in check until I can get past the speed at which the wobble would start. Also, the surface that you are driving on can be a big factor in starting death wobble. I couldn't run past 35 on pavement without getting wobble, but on dirt/grass, I could run as fast as I ever wanted to and would never get a wobble.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #13 of 14 Old 08-21-2017, 03:29 PM
Ross
My experience death wobble comes on at lower speeds and out of balance shakes at higher speeds.
Out of balance shakes are predicable, they will act up at the same speeds. Death wobble for me has happened at lower speeds. Things that have triggered it is turning or even a bump in the road.
The times I have had death wobble were because of a loose track bar. There may be others things that cause it.
For me tire wobbles have been balance or wear issues on tires.
The difference: steering wheel shakes a little
vs. STEERING WHEEL GOES ****ING NUTS!!!!!!!!!!!!!!!
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #14 of 14 Old 08-21-2017, 05:27 PM
OldJackTheJeep
Yes stick to ironing.
OldJackTheJeep is offline
