Dana "slow" carrier? - JeepForum.com
post #1 of 4 Old 01-25-2003, 10:45 AM Thread Starter
BillR
BillR's Avatar
This is one for you folks that've been around Jeeps awhile.
What is ment by the term "slow carrier" when refering to a Dana 30? carrier? (or most any Dana carrier)
I saw a website that sold a "fast" carrier and a "slow" carrier for a Dana 30. I assume this refers to the axle ratios, but which is which?
Thanks.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #2 of 4 Old 01-25-2003, 04:10 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would imagine the "slow" carrier is for the 3.92 and steeper gears and the "fast" carrier is for the 3.73 and taller gears... steeper.. taller... more confused now?
BESRK is offline
post #3 of 4 Old 01-25-2003, 04:24 PM Thread Starter
BillR
BillR's Avatar
I hope that's the case. I bought an LSD carrier that says "Dana 30 slow" on the box, and I'd like to install 4:11s. I have a standard carrier for 4:11s, and they LOOK to be equal in size and pattern.
If you had a 3:07 carrier and a 4:11 carrier, what difference would you see? How could you tell them apart?
TIA!
BillR is offline
post #4 of 4 Old 01-25-2003, 09:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The ring gear mounting flange will be different between the two. If you're holding the carrier in your hands with the ring gear flange on the left side, the 4.11 carrier would have the ring gear mounting flange farther to the left. The 4.11 uses a thicker ring gear and smaller pinion gear than say... a 3.07. If it's not the right one... you'll know when you try to install it.. it absolutely will not fit. Ask me how I know
BESRK is offline
Fold "down" spare tire carrier Floridazed Fabrication Shop 37 03-27-2011 07:51 PM
Need Help Deciding on Powertax "No-Slip" or full carrier Detroit 1badxj General Jeep & Off-Road Equipment 3 03-15-2009 10:32 AM
Detroit autolocker in front dana 30--- 35"s with a 33" spare ok? Blk2kTj Engines & Drivetrain 9 02-27-2007 08:50 PM
Is there a "bolt in" Dana 44 for YJs? ElvisV04290 Engines & Drivetrain 10 02-03-2007 10:46 AM
"Posi" carrier vs "Open" in Dana 35? Big92Jeep General Jeep & Off-Road Equipment 6 11-18-2001 03:24 PM
