dana 60 high steer arms renforcement
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#1 | |
i figure i would post up on how i solved my problem of the top king pin bolts loosen on my dana 60 high steer arms. after every run out the arms would be very looes and it was only a matter of time before i stripped one or worse sheer the bolts off and this kept me from going full hydro. so i took a piece of 3/8 T-1 welded it to a piece of 1.5'' 1/4 thick T-1. the 1/4'' steel had the holes drilled to match the high steer arms. i then bolted the wedge ( made out of the 3/8 and 1/4'' ) and welded it to the OEM ford knuckle, witch has the thinest of the big three dana 60's.
now after alot of hard runs out the king pin bolts are not even out of tourqe, so they have'nt even budged. i also have no fear runing full hydro now and the knuckles should be the last thing to break. heres some pictures, jason.
#2 |
GSMW!
Looks like a good way to gain some strength
Question: are you using just regular grade 8 bolts to attach your high steer arm? ![]()
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#3 | |
#4 |
Some Call me RockDog
looks good
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#5 |
GROUND POUNDER
Studs with conical washers and nuts... been running them for 3 years without breakage or loosening.. 42" TSLs, full hydro, and no regard for driveline abuse.
Edit: Oh.. and that is a nice fix and welding!!
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#6 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
