Dana 35 chromoly 27 spline axle shafts - JeepForum.com
post #1 of 4 Old 08-09-2008, 03:04 PM Thread Starter
LCTJ02
Is anyone using or used yukon's dana 35 chromoly axle shafts. They still are 27 spline but use 1541H material. They say they're 25% stronger over stock. Worth it?
*please spare the dana 35 rants, thanks.
LCTJ02 is offline
post #2 of 4 Old 08-10-2008, 07:00 AM
Pillswoj
Several people are using the yukon shafts, they are a good upgrade for mild wheeling also if you a running a tru trak limited slip that is only available in 27 spline.
The Yukon's are a stronger then stock alloy, but not chromolly. Check http://www.atozfabrication.com/catal...ends-p-71.html for SAE 4340 chromolly axles.
I am not sure of the difference between the 1541H and the 4340 alloys for strength maybe someone will chime in with info.
Jeff
Friends don't let Friends run Bosch
Pillswoj is offline
post #3 of 4 Old 08-10-2008, 10:35 AM Thread Starter
LCTJ02
I did some research and found this....
"For high performance applications, 1541h steel is an excellent choice. 1541h steel contains a lot more manganese than 1040 or 1050 steels, which adds strength, hardenability, and helps in deep heat-treating. Deeper heat-treating and greater strength are a few of the reasons 1541h is used for high performance and custom axle shafts. It is much stronger than 1050 steel without being a whole lot more costly. The durability of this alloy is very good as long as the heat-treat procedures are completed correctly. 1541h steel is approximately 20 to 25 percent stronger than 1040 steel used in OEM axle shafts.
In extreme high performance use where twisting torque is important but bending stresses are limited, 4140 or 4340 chromemoly alloy steels work well. 4140 chromemoly provides approximately 27 percent more strength than 1040 steel, while 4340 chromemoly provides approximately 39 percent more strength than 1040 steel. This translates into huge gains in twisting strength as long as bending will not be an issue. 4340 is approximately 10 percent stronger than 4140 due to the addition of more nickel, which increases toughness and strength."
http://www.nsor.com/featureditems/yukon%20axles/
LCTJ02 is offline
post #4 of 4 Old 08-10-2008, 10:46 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The very slight gain in strength is not worth the cost of the kit to only stay with 27 splines. The only worthwhile upgrade to the Dana 35c is with a "real" Super 35 kit that upgrades them to hardened 30 spline axleshafts. Really.
Jerry Bransford is online now
Aftermarket shafts for dana 35 27 spline? Hussler Engines & Drivetrain 11 11-26-2009 12:42 AM
Upgraded D60 to 35 spline an axle shafts are too BIG!!!??? 488TJ Engines & Drivetrain 14 11-20-2009 08:40 PM
Upgrading the D30. Where to get chromoly shafts? Lud04X Engines & Drivetrain 5 12-27-2007 02:40 PM
Who sells alloy 27 spline dana 35 shafts? AdamB Engines & Drivetrain 4 06-27-2006 07:32 AM
dana 44, arb, and 35 spline shafts!!! rsoffar General Jeep & Off-Road Equipment 2 10-03-2005 02:31 PM
