Dana 30, 35, 44 axles and lockers swap - JeepForum.com
post #1 of 5 Old 06-04-2013, 02:42 PM Thread Starter
RockyFields
Hey
I have a 1999 TJ Sport with dana 30 front and dana 35 rear axles. I am looking into buying lockers to put on them.
This past weekend I was down in indiana for the Badlands Jamboree, and met someone who is selling his TJ Rubicon dana 44 axles and lockers. He will sell them to me for $3000 everything included.
First off, should i buy them or should i buy lockers and put them on my current axles?
second, how easy or hard would it be to install his axles on my TJ sport.
what sounds like the best option to you all?
RockyFields is offline
post #2 of 5 Old 06-04-2013, 07:11 PM
biffgnar
biffgnar's Avatar
That's a pretty typical price for Rubi axles. Regearing your current axles and installing air lockers will probably cost you around the same amount. Realistically though you don't want to put a locker in your D35 and the upgrade to the D44 in the rear is a big improvement. Find out exactly what "everything included" means. Compressors, ebrake cables, maybe driveshafts, etc.? Faced with only those two choices I'd say get the Rubicon axles, although overall there may be better ways to spend $3000 on axles.
Axle swaps aren't hard. You're mostly just unbolting old stuff and bolting up the new axle. First time I did one took me a day for one axle although that was by myself.
Romney in 2020!
biffgnar is offline
post #3 of 5 Old 06-05-2013, 08:49 AM Thread Starter
RockyFields
what is a better way to spend $3000 on axles.
also ive heard that i may need to shorten my driveshaft to fit the dana 44 axles. is this right? and if so how hard and time consuming would it be.
thanks a ton!
post #4 of 5 Old 06-05-2013, 09:00 AM
biffgnar
biffgnar's Avatar
thanks a ton!
Biggest question, do you need air lockers? Those are probably the most expensive option out there. For some people (myself included), selectables were a requirement and I did go with ARBs. For many people though auto lockers or even LSDs are viable and cheaper options.
Yes, your existing rear driveshaft will potentially be too long. That's why I listed the driveshaft as one of the potential things to ask about when defining "everything".
Romney in 2020!
biffgnar is offline
post #5 of 5 Old 06-06-2013, 11:37 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you're looking to upgrade, the rubi axles are definitely worth it over the stock 30 and 35. Depending on what gears you have, it may actually be cheaper to install the set of axles than to regear and add strength to the current setup.
Luck Favours The Prepared
Anticanman is offline
axles , dana 30 , dana 35 , dana 44 , tj
