Could a hub puller damage the axleshafts or diff? - JeepForum.com
post #1 of 2 Old 12-02-2013, 11:18 PM Thread Starter
AVR2
I recently did the lower balljoints on my 2005 Liberty, and since it was the first time I've ever had the front hubs off, I had a hub puller standing by. It worked like a charm on the passenger side, with the puller first separating the hub from the knuckle, and then pushing the axle shaft out of the hub splines.
On the driver side, though, the first thing the puller did was separate the shaft from the hub. When I tried tightening the screw to make it push the hub out of the knuckle, I could feel the shaft compressing - all I was doing was pushing it back towards the diff, so the puller wasn't exerting force on the hub.
I didn't want to go any further in case I damaged either the shaft or the diff, so I ended up having to use a hammer (carefully) on the hub flange to break it loose from the knuckle.
Bottom line - could I have kept cranking on the puller screw until the shaft stopped compressing and the hub started to come loose? Or was I actually in danger of causing damage to the shaft or diff by pushing the shaft too far back into the Jeep?
AVR2 is offline
post #2 of 2 Old 12-03-2013, 06:03 PM
rjbruzan
The hammer method is OK. Or knocking out from the rear. If the hub is being replaced a big hammer is better.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
