Converting a portable smittybuilt compressor to onboard air - Page 3 - JeepForum.com
post #31 of 36 Old 08-24-2013, 02:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
One thing with the smittybilt compressors: GET THE WARRANTY!!
I just swapped for my third compressor and it was worth the extra $30. It used to take about 30 minutes with the busted compressor to get to 105psi in my one gallon tank and now it takes less than a minute. It takes four seconds to bring it from 85-105 psi. If I had it to do all over again I may have purchased a viair or ARB compressor but for what I have into it, its still a perfect fit. I can't drive in this traffic without train horns, I would have been killed by now.
Luck Favours The Prepared
Anticanman is offline
post #32 of 36 Old 08-24-2013, 04:10 PM
biffgnar
biffgnar's Avatar
Originally Posted by bbradUSMC View Post
Where did you pick up your york?
Live Free,
Brad
Junkyard. If you google it there are lists of donor vehicles. If I recall mine was from a Volvo. The compressor is the easy part. Getting a mounting bracket that works for your jeep is the hard part and then all the little bits and pieces is the PITA part.
Romney in 2020!
biffgnar is offline
post #33 of 36 Old 08-24-2013, 04:12 PM
biffgnar
biffgnar's Avatar
Originally Posted by purplepig View Post
I hard wired a Viar 450 portable 100% duty cycle and I have thought about adding a tank too. What is the difference btw this setup and other setups with a tank?
See comments earlier in the thread. Unless your tank is big (i.e. bigger than fits conveniently in most jeeps) not going to make a material difference.
Romney in 2020!
biffgnar is offline
post #34 of 36 Old 08-24-2013, 04:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here is a good list
http://www.links4jeeps.com/writeups/...ork_Donors.php
post #35 of 36 Old 08-24-2013, 05:12 PM
bbradUSMC
Awesome, thanks. Does it matter what head type?
Live Free,
Brad
bbradUSMC is offline
post #36 of 36 Old 08-28-2013, 02:43 PM
Ross
I have had the smittybuilt for a few years now. About a year ago I mounted behind the rear seat. It is allot more convenient to have it mounted. I did miss the flexibility of being able to take it with me so I went out and bought a second one.
For the 70 bucks or so they are a good inexpensive option for having air.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
air compressor , wiring
