CO2 OBA from fire extinguisher, - JeepForum.com
post #1 of 11 Old 07-14-2007, 09:05 AM Thread Starter
CJATE
At work, I come across fire extinguishers all the time, they are aluminum so we usually recycle them.
Never thought about making an OBA tank until I saw the keg thread, and did not want to hijack it.
Possible? I got a big one at the office, I was going to recharge as an extinguisher, but would rather have OBA.
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #2 of 11 Old 07-14-2007, 09:25 AM
Happy Joe
Most extinguishers are powder not CO2 (powder extinguisher tanks are too weak to safely support CO2 pressures, but will be OK for use as an OBA compressor surge tank at pressures near 100 PSI).
If you have a CO2 extinguisher its possible but it depends on the threads on the tank. Some extinguishers use a non standard thread.
I would ask the guy at the gas distributor if they can sell you a valve and if it will fit. (also if they would be willing to fill it after the conversion) (you will almost certainly have to repaint it and have it pressure tested)
Enjoy!
Happy Joe is offline
post #3 of 11 Old 07-14-2007, 09:50 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I have 2 CO2 extinguishers here are what they look like:
http://www.smokesign.com/cardioxfirex.html
CJATE you will be fine using it as OBA, you need to get the right valve body to make sure the Highflow when filling you tires and the PSI are reduced to a managable level and to hook up your air line to. IIRC Power tanks got their start by using "old" fire extinguishers that were recertified, fitted with acutriments, painted and sold.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #4 of 11 Old 07-14-2007, 03:21 PM
1984CJ
1984CJ's Avatar
You should not try and use a Dry chemical fire extinguisher tank for a CO2 onboard air system. From what I found Dry chemical tanks are only rated for a working pressure of ~200 psi.
CO2 Fire extinguishers are rated much higher with a working pressure of 850PSI. Hydro tests on the bottles are generally run at 5/3 that pressure or ~1417psi.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #5 of 11 Old 07-14-2007, 08:47 PM
Happy Joe
Schitzangiggles; you did not read my post. Try again!
Enjoy!
post #6 of 11 Old 07-15-2007, 09:27 AM
ZIMSJEEP
ZIMSJEEP's Avatar
I have a pressurized water fire extinguisher rated up to 180 psi. Would this work? My only concern is how to mount it.
3.5" Fabtech lift, 5/8" MORE Boomerang Shackles, Brown Dog Motor Mounts, 33x12.5 Mikey Thompson Baja Claws, MT 15x8 Classic II Alloys, JKS swaybar disco's, Rancho RS 5000 stablizer, Skyjacker Hydro 7000 shocks, Warn Bumper w/ pre runner, On board air, Grant Wheel, PIAA Windshield mounted lights, Herculined Interior
ZIMSJEEP is offline
post #7 of 11 Old 07-15-2007, 12:31 PM
Happy Joe
It will work as a compressor surge tank, it will not hold liquid CO2 pressure (as mentioned liquid CO2 needs a high pressure tank, or CO2 extinguisher tank).
The water extinguishers are the ultimate squirt guns though.
Enjoy!
post #8 of 11 Old 07-15-2007, 07:08 PM
ZIMSJEEP
ZIMSJEEP's Avatar
I should have been more clear...I'm not planning on using CO2. I'm using air from my stock AC compressor. Will the extinguisher work?
ZIMSJEEP is offline
post #9 of 11 Old 07-15-2007, 09:31 PM
deathblade556
Sure a fire extinguisher would work as a tank for our AC/air compressor just make sure you have a safety valve and a pressure switch to cut the compressor out when the PSI gets higher 110-120psi. This is what I'm planning to use with my OBA setup, the hardest part is finding the right fittings/threads.
2000 Forest green TJ SE with stock gears, sport king 31x10.50s, a 4 cyl 2.5l, 3speed auto, now with 100,001 miles on it as of 3/27/09 10:43:51am
Low Output 4 Cylinder Jeep Club Member #71
deathblade556 is offline
post #10 of 11 Old 07-16-2007, 02:57 PM
geauxturbo
geauxturbo's Avatar
I'll trade you a Scotts air tank rated up to like 3000 psi for the CO2 tank Same size a 10 lb CO2 Fire Extinguisher.
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
geauxturbo is offline
post #11 of 11 Old 07-21-2007, 02:09 AM
schitzangiggles
King of Macastan
Enjoy!
You are correct. I am retarded my applogies sir
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
fire extinguisher eagles4094 Cheap Tricks & Fixes 61 02-08-2015 11:03 PM
What to look for in a fire extinguisher Rush1184 General Jeep & Off-Road Equipment 20 09-23-2011 03:12 PM
fire extinguisher frumpy General Jeep & Off-Road Equipment 8 07-03-2006 01:04 PM
Fire extinguisher dirtbagofva General Jeep & Off-Road Equipment 10 12-08-2005 12:31 AM
Fire Extinguisher FlyersFan2009 General Jeep & Off-Road Equipment 8 12-28-2004 10:17 PM
