Clutch Replacement cost - JeepForum.com
 2Likes
post #1 of 22 Old 09-29-2010, 11:27 AM Thread Starter
HighRoller02TJ
i have an 02 TJ 4.0L, im dropping it off next thursday for a new clutch. what should i be prepared to pay? Thanks
HighRoller02TJ is offline
post #2 of 22 Old 09-29-2010, 11:30 AM
g4x4xgeoff
about 200 in parts, couple hours in labor
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #3 of 22 Old 09-29-2010, 12:16 PM Thread Starter
HighRoller02TJ
what shop will do it for 200 in parts and 2 x hourly rate? because i just got some quotes of 600 - 800
post #4 of 22 Old 09-29-2010, 12:18 PM
g4x4xgeoff
well, figure 65 plus an hour...it'd take a regular joe about 4 hours...you're looking at a minimum of around 500.
Get a guy who knows jeeps well, it'll take him less him (I have a guy who can swap an auto to a manual in 3 hours) and the time will be less, but he charges 100 an hour.
post #5 of 22 Old 09-29-2010, 02:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A complete clutch Luk clutch kit from www.dialaclutch.com/ is only $160. It includes everything... clutch disk, pressure plate, throwout bearing, pilot bearing, and pilot shaft. Don't let the shop talk you into a Centerforce clutch kit, they are WAY more expensive than they should be and they have no benefit over the Luk clutch kit. The factory even installs Luk clutches.
rubiconrich likes this.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #6 of 22 Old 09-29-2010, 03:09 PM Thread Starter
HighRoller02TJ
good tip, whats a centerforce go for?
post #7 of 22 Old 09-29-2010, 03:42 PM
electrichead
Clutch job for TJ's book for 5 hours. Most shops will do it in less though.
- My 2005 Rubicon Unlimited Build -
electrichead is offline
post #8 of 22 Old 09-29-2010, 04:17 PM
Jerry Bransford
Administrator
$260-270 and higher from what I can recall.
Getting
post #9 of 22 Old 12-10-2010, 11:26 AM
joeranger
I saw only one clutch on Quadratec for $449. Says 4-6 hours install. Am I looking in wrong place?
Centerforce Dual Friction Clutch
For 07-08 Jeep® Wrangler & Wrangler Unlimited JK
Quadratec Part No: 52030.1100
Manufacturer Part No: DF098391
$449.99
joeranger is offline
post #10 of 22 Old 12-10-2010, 12:01 PM
joeranger
My dealer quoted $600 for the new clutch for 08 wrangler 4dr
I did call dialaclutch. They said that the factory clutch is this one.
01-046 - Jeep Liberty Clutch Kit
Our Price: $268.49
Product Code: 15610
Description
Jeep Liberty Clutch Kit - Luk
Part No.: 01-046
Application:
Engine: 4 Cylinder
Disc Size
Outer Dia:
Spline:
Teeth: 0
post #11 of 22 Old 12-11-2010, 05:53 AM
TimV
Most shops also mark up the parts cost as well. Sometimes almost 100% markup. Helps them make extra on top of the labor costs. Going rate for labor around here is about $80 an hour, so $600-800 doesn't seem unreasonable in my mind. That being said, I wouldn't pay that.
It's not an addiction. It's a way of life.
TimV is online now
post #12 of 22 Old 12-11-2010, 08:36 AM
notmyj
Don't forget that what you can buy the parts for, is NOT what the shop is gonna charge you. The shop is gonna charge List price. This is why most shops wont install parts that you supply. Also, most shops won't charge you actual time. They will instead charge you "Book Time". Meaning, they look up the job in a book and it states x.x hrs. They multiply that by shop rate, viola, you have the labor costs.
This is how most mechanics make their money (or loose their *****) its called flat rate. Say replaceing a clutch takes 4hrs book time. The mechanic gets it done in 2hr. The customer will get charged for 4, and the mechanic gets paid for 4 hrs. (Mechanics typically make 20% of shop rate) So just because the guy can do the swap in 2 hrs, doesnt mean you will get charged for 2 hrs.
Hell, I do alot of side work, and I charge 40/hr and I charge half the difference list vs retail on parts. I make money, and the people get pay almost half of what a shop will charge them. Then again, even the Monroe Muffler down the street is at $98/hr labor.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #13 of 22 Old 12-13-2010, 09:58 PM
AmnWatkins
I'm getting mine done tomorrow (YJ) and they're installing a clutch I bought from Schucks. I'm also getting the whole tranny rebuilt though. They quoted my about 8 hours to pull, fix, and intall the tranny for about $800 dollars labor then another few hundred in parts for the rebuild. told me about $1000-1200 total.
Check the air tires, thats where the power is generated.
AmnWatkins is offline
post #14 of 22 Old 12-29-2010, 06:45 PM
Dsmall0491
wow, 1000 would not be bad at all for a rebuild and clutch job....
Dsmall0491 is offline
post #15 of 22 Old 07-15-2012, 08:31 AM
swright227
Price quote
I have a 1988 YJ. I got a quote of $900.00 for parts and labor ( new pressure plate, clutch disk, slave cylinder, pilot bearing) from one shop. Another shop qouted me a labor only rate of $600.00 if I provided all of the parts. I'm in Florida north of Tampa.
swright227 is offline
Squishy clutch then the clutch just locked up completely is it the master, slave or ? GPII Engines & Drivetrain 1 11-25-2011 07:36 PM
1995 Wrangler clutch replacement question? thekauz Engines & Drivetrain 10 12-14-2009 01:50 PM
Pricing on clutch replacement on 94 XJ??? PR_XJ1994 Engines & Drivetrain 0 10-16-2008 05:36 PM
manual bellcrank clutch vs Hydraulick clutch jphillips13 Engines & Drivetrain 1 07-09-2008 09:25 PM
Clutch Replacement jmkurt Engines & Drivetrain 3 11-01-2006 05:34 AM
