CJ7 tub repair? - JeepForum.com
post #1 of 6 Old 06-27-2006, 07:02 AM Thread Starter
rob5059MOD
rob5059MOD's Avatar
CJ7 tub repair?
On my CJ7 I have a lot of rot on the drivers side of the tub from the door to the rear corner. My thought was to cut out the rot and replace it with sheet metal, but what is the best way to attach the replacement sheet? Can I use a MIG welder, or should I rivet the sheet in place? How much overlap should I have between the new sheet metal and the existing tub?
Sorry for the really dumb questions, but this side of the Jeep is a little more then some bondo or fiberglass.
Thanks Rob
07 JK Rubicon
SOLD 06 Wrangler Unlimited Khaki, Congo Cage, D30 w/Aussie & D44 w/ Limited slip and 3.73 gears, 231HD transfer case with 2LOW and JB Conversions SYE with a Tom Woods DS. LIFT: Full Traction 4" Ultimate lift and JKS BL, Brown Dog MML. SKIDS: Jeep Medic TT and Oil Pan, Warn Gas Tank, and Rusty's Steering Box & Radiator. STEERING: ZJ steering, and PCS Steering Box. Running on 35" BF Goodrich Mud Terrains. And to ruin the look, I added Warn 6" flares to keep it legal.
rob5059MOD is offline
post #2 of 6 Old 06-28-2006, 03:23 PM
scarface97
Mig, spot welding it in, jumping around alot as to not distort, 1/16 gap at most
'97 TJ Rockwells,360 on P-pane, 44's but not as
cool as yours
TJ on Rockwells Club Member #1
scarface97 is offline
post #3 of 6 Old 06-28-2006, 05:55 PM Thread Starter
rob5059MOD
rob5059MOD's Avatar
Thank you scarface97!! I will give it a shot, I can not make it any worse then what it is.
07 JK Rubicon
post #4 of 6 Old 06-29-2006, 12:02 PM
scarface97
You are right on that, just get the cancer out and work what you can metal wise.
It will add character
cool as yours
post #5 of 6 Old 06-30-2006, 09:56 PM
kbazurpe
kbazurpe's Avatar
1973 CJ5
I could email you some pictures of how I took care of my floor boards. Send me a pm if your interested.
kbazurpe is offline
post #6 of 6 Old 07-01-2006, 10:54 PM
brypten
you could rivet it, but I don't think that it would look very good. Weld it with as smooth of a bead as you can get, then grind it smooth. On my CJ5 I covered a lot of the rot (i put penatrol on it first to stop any further rust) with diamond plating The diamond plating I did rivet on though
brypten is offline
trail repair 8balls12 Fabrication Shop 3 05-03-2009 01:33 AM
Stock Sub Repair Kit Mrcln1 Audio, CB & Ham Radios, GPS, & Electrical 0 02-21-2009 07:22 PM
Tub Repair Panels? harley2003rkc Fabrication Shop 2 10-22-2008 11:07 PM
Beyond repair? The Von General Jeep & Off-Road Equipment 1 03-29-2008 03:02 PM
