> General Technical Discussions
> General Jeep & Off-Road Equipment
chicago 10,000 lb winch
08-26-2006, 04:27 PM
#1
I don't know if this is the right forum, but I just thought I would let you all know that I just picked up a harbor freight ad and they have the chicago 10,000 winch in the ad for $399.00. Price good till 08/28. It says marked down from $599.00. Either way, couldn't find it that cheap online anywhere. If you are looking for a cheap winch it's a good deal.
motox
Without Struggle there is no progress.
08-27-2006, 05:57 PM
#2
I picked up the 10k a while back - go on line and find a 20% discount coupon. you can get the winch for $319.00, that is what I paid.
Have had no problems with it and I replaced a HF 8000 lb with it. never had a problem the the 8k either.
Good luck.
97 TJ
08-31-2006, 02:55 PM
#3
If you get a chance, take a close look at a MileMarker electric winch and those Chicago Electric ones that Harbor Fright sells.
YEP, they are identical. Same winch. Sometimes you can find the Mile Marker priced cheaper.
Turbocharge it!
Then I'm interested!
'94 ZJ Limited Lifted and LOCKED!
'04 Durango Limited (the wife mobile)
'72 Plymouth Satellite Sebring Plus (Resto MoPar)
08-31-2006, 03:34 PM
#4
i wish i read this three days ago when I had $$ and the deal was still available
lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00
44p '03p '6ı :5ɾɔ,37
s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47
The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad
08-31-2006, 05:07 PM
#5
I looked long and hard at the HF 10000# during this sale price period. Looked at every winch I could find info on. I'm on a very small budget so I finally went with the Costco Champion 8000# for $299. I bought the HF Jeep winch plate for $39. Will be installing it this weekend. So, in buying cheap, I spent about $$$ less, got a series wound winch, a great warrenty (I know the warrenty doesn't matter when I'm walking out of the woods), about 18# less weight on my bumper, and most importantly, finally have a WINCH.
08-31-2006, 07:41 PM
#6
You sure the Champion has a series wound motor?
'01 TJ. 4"Full Traction. 1" BL/MML. 35" BFG Muds. ARB's front & Rear. Full skids. Warn Winch. Lots of other crap!
08-31-2006, 08:55 PM
#7
what is a series wound motor?
08-31-2006, 09:27 PM
#8
Sure does, I have one too, and know the manufacturer, makes the mile marker also......
[B]Engine:[/B] 4.2L L6 258 [B]Trans:[/B] Automatic
[B]Carb:[/B] Stock 2Brl [B]Exhaust:[/B] Dynomax
[B]Ignition: [/B]Stock [B]Suspension : [/B]1" Prothaine Body Lift
[B]Rims:[/B] Stock [B]Tires:[/B] P235/75R15 [B]Wench:[/B] 7500lb Champion
[B]Interior:[/B] Bedlined [B]Paint:[/B] Custom Camo [B]Driving lights:[/B]Hella 500's [B]Rear Lights:[/B]50w Halogen
[URL="http://www.cardomain.com/ride/2426963"][B][COLOR="Silver"]My Jeep Website[/COLOR][/B][/URL]
09-01-2006, 08:40 AM
#9
Do it right or not at all
If it were me, I'd drop down to an 8,000 or 9,000 lb. version of that winch to save weight. To me, a 10K winch is unnecessarily heavy when a slightly smaller winch is more than enough for a Wrangler size vehicle.
09-01-2006, 10:19 AM
#10
According to the spec sheet the motor is Series Wound 3.6HP with gear reduction ration of 210:1 I know it won't be a speed demon but there are a number of higher cost winches that are much slower. The bottom line for me was not a decsion of getting a Warn vs "cheepo" winch, but rather a "cheepo" vs NO winch. The frosting is if should it ever break, after the hike and a tow, I can return/refund back to Costo.
09-02-2006, 10:43 AM
#11
Winches either have "series wound" or "permanent magnet" motors. A series wound motor will have a longer life. In fact, it's this spec that I consider first when considering a winch.
I don't blame you. I'd consider a winch with those specs as well. This seems like a much better winch than the Harbor Freight with a 1.8 HP permanent magnet motor!
