chevy 350 and 36''s - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > chevy 350 and 36''s
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 12-19-2005, 07:33 PM   #1
grandman97
chevy 350 and 36''s
ok so i'm planning my lift for the YJ and i am worried that when i go to 35 or 36'' tires w/ the chevy 350 that my 8.8 will explode quite easily... am i correct in assuming this??? what rearend should i use?? d60?? also what front end would i have to slide under there?? would a d44 be enough or no... i need lots of info boys help me out
grandman97 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 10:25 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen a couple of my buddies abuse their 8.8s with 35" tires quite regularly with minimal problems. One of them did break his companion flange at Tellico and he also grenaded the carrier on another run but he hammers down pretty hard. I'd just run it till it breaks and then upgrade to a D60. A front D44 should hold up pretty well with 35s. I had no problem (before I went to a D60) with mine and 35s. That was with a 350/NP435/D300 and a heavy foot. Might wanna go with alloy axles and tougher aftermarket ujoints. If you install them before breaking the stock stuff, you can have the stockers as spares..
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 12-19-2005, 11:20 PM   #3
grandman97
thank u sir.. i was hoping you would be the one to answer me on this one btw i envy the lime
Unread 12-20-2005, 06:26 AM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thank you.. now you just have to envy my credit card bills
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 12-20-2005, 08:42 PM   #5
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Mike, that 8.8 will take a LOT more than you think. Seems that the common failure of the 8.8 is the carrier. Go for a full Detroit or ARB and this problem has been solved
Also, smart lines will get you further than HP!
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote Quick reply to this message
Unread 12-21-2005, 12:55 AM   #6
grandman97
yea but smart lines are usually boring.. just like at paragon i knew i didnt have to go in that ditch but i did anyway to make things interesting..... my only problem with taking the more "challenging" lines is my rig is usually not capable enough of doing what i want it to do so i need a really good spotter to get me out of the crap i just got myself in ...... speaking of paragon... Tim- what ya doin the weekend of Jan. 28th?
Unread 12-22-2005, 05:39 PM   #7
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Just because the line someone picked was a smart one, doesn't mean it wasn't challenging or hard
Mike, I wish I could come to the winter run, however, I'm in the middle of prepping for both axle swaps and some other upgrades, I'm not sure I can get away
KD8EBC
'94 ZJ 5.2 LTD
Unread 12-23-2005, 12:29 AM   #8
grandman97
BOOOOOOOOOOOOOOOOOOOOOO...just kiddin man if i break anything this run (which i will) i probavly wont be able to go on another trip till mid spring..... hey whatever happeneed to that t-case i got to you??
Unread 12-23-2005, 02:13 PM   #9
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Going in next week! Just finished cleaning it up after the tear down and reassembly. I just need to get a new rear out-put seal.
KD8EBC
'94 ZJ 5.2 LTD
