Cherokee or bronco - JeepForum.com
post #1 of 4 Old 05-11-2013, 09:14 AM Thread Starter
czerbel
Cherokee or bronco
So I'm debating what to get and I need some help. I either want to get a xj cherokee 97-00 or a ford bronco xlt 1980-86 but was wondering if just that much size difference would hinder the bronco on the rubicon? Either one I get will eventually be on Dana 60s and 37s help me out it would be awesome if some could tell me if they have seen fullsize broncos do the rubicon
czerbel is offline
post #2 of 4 Old 05-11-2013, 10:59 AM
222Doc
222Doc's Avatar
well the Rubicon after last year was about leveled by the Forrestry. I was lucky enough to be there last year before they leveled the little sluice, the old big sluice, the rock and tree squeeze, moved the rock. few years back the leveled the gate keeper. So Now you can do it on 32" no lockers in a subrban. The thing that was odd was other than that tree squeeze. There was go arounds for everything else. I have seen full size pick ups out there.
The group we ran it with from AZ. There was one Jku that only had 33"s no lockers. he made it no dents, excepting under it. So its not like it was now. If you want a test of your rig, Fordyice short but very hard. Or the Dusy longer than the Con and enough rocks lakes and streams to keep the adventure, though the Dusy has very short season. its at a very high elevation. We are going to the Dusy this year and Fordyice the next, maybe.
222Doc is offline
post #3 of 4 Old 05-11-2013, 08:18 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
depends on how much work you want to put into it.
stock for stock, i'll take the XJ any day. but you start upgrading, Give me the bronco. It has one HUGE advantage over XJ, that being it has body on frame construction. when you start wanting to add full size axles and big tires you are talking big mods to the XJ, where as the bronco would be an easier swap to heavier axles with less work needed to do so.
as for fitting, you wheel a full size rig, body damage comes with the territory. will they go where a jeep can? of course, but they collect more battle scars along the way.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 4 Old 05-12-2013, 09:58 PM Thread Starter
czerbel
Thanks for the feedback guys. Ya I've had both and I loved both the xj was 3 link long arm with frame stiffeners non locked 35s been through rubicon by previous owner and the bronco was a tank except it was carborated so it died alot
czerbel is offline
