change and repack bearings - JeepForum.com
post #1 of 8 Old 10-18-2001, 07:54 PM Thread Starter
mytjnamedrex
I have this squeaking noise that is coming from the front end and it has to do with either bearings or brakes. it is worse when cold and is not constant. When i tap the brakes it goes away but will come back. It is come and go all the time but is worse at slow speeds and is gone by sbout 35mph. please help!!
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 8 Old 10-19-2001, 09:36 AM
osburn
osburn's Avatar
The bearing/hub assembly on your front end is unserviceable. You just replace the whole assembly if it fails. Can't help ya on the squeek.
Matt Osburn
Score 1032
osburn is offline
post #3 of 8 Old 10-19-2001, 02:06 PM Thread Starter
mytjnamedrex
my girlfriend has a 99 cherokee and its doin the same thing. She got the bearings redone and it didnt help. What could it be? brakes?
post #4 of 8 Old 10-19-2001, 07:44 PM
I-4
I-4's Avatar
not asking this to be an a$$-do you drive like hell?it might be that your brakes are glazed over.or might be a slightly loose brake pad in the caliper.if you drive like hell,might be a warped rotor from an "oh sh*t!" stop.i would lean towards glazed over pads.just my $.02.hth. i found this out the hard way on my first car pretending i was speed racer-had a very similar problem.plus you probably have composite type pads on your jeep,they work better after they warm up a bit-the rr taught me this one.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #5 of 8 Old 10-20-2001, 10:47 AM Thread Starter
mytjnamedrex
well i did have an oh ***** stop a few weeks ago on my way to a trail and then i was on the trail and did water crossings and stuff like that. If the brakes are glazed what can i do? if a pad is lose what can i do? Im pretty sure IF it is a warped rotor that thatll haveta be replaced but im hoping its not that bad. ...to answer your question i drive a lil aggresive but i dont slam on brakes unless i must. I know the one time where a suburban pulled out in front of me on a two lane street when the speed limit was 45 and i had to do a 52-0 stop and ABS clicked in on dry pavement, it was very abrupt. thats the only time and it was the time i mentioned above on my way to the trails. thanx
post #6 of 8 Old 10-20-2001, 11:37 AM
I-4
I-4's Avatar
a brake job might help.i did pads and calipers on my 95 yj for about $60.if your rotors are warped,there is a possibility it can be turned(depending how warped they are)shouldn't cost more than $30-$40 to have them turned(if it is even that much)some autozones turn rotors.i would take it to your mechanic and let him turn them.if a pad is loose(shouldn't be unless work has been done on your brakes recently)you can take and bend the retainer back into place.the best bet is to get a haynes or chilton's manual and follow it.hth
the oh sh*t stop gets your rotors really hot,then playing on the trail through water and stuff cools them off really quickly,that could be how your rotors might have gotten warped.
95 yj...
I-4 is offline
post #7 of 8 Old 10-20-2001, 12:22 PM Thread Starter
mytjnamedrex
thanx for the quick reply...im gonna take it and have it looked at hopefully this week.
post #8 of 8 Old 10-21-2001, 12:10 PM
I-4
I-4's Avatar
keep me posted about what you find...
95 yj...
I-4 is offline
Pressing bearings on and off. BozoWise Engines & Drivetrain 1 11-19-2007 10:03 PM
Dana 35 bearings vbguru12000 Engines & Drivetrain 1 11-05-2007 11:17 AM
S30 - Same carrier bearings? tommaho Engines & Drivetrain 3 12-19-2006 09:42 AM
wheel bearings jeepwcrazy Engines & Drivetrain 1 11-28-2006 06:32 PM
inner bearings got spun? DLoweinc General Jeep & Off-Road Equipment 2 02-09-2005 05:09 PM
