CEL code P0420 O2 sensor How to pinpoint the bad one? Help please. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > CEL code P0420 O2 sensor How to pinpoint the bad one? Help please.
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-18-2014, 04:26 PM   #1
jeepjunkie21
I have an 04 LJ. My check engine light has been coming on and off for the last 7-8 months. Its been the same code each time. P0420. Basically it says its a bad cat, engine mechanical problem, or bad o2 sensors. Im assuming that since the light is turing on and off every couple months, its an O2 sensor. cause the engine runs and sounds fine. just the noisy lifter that is notorious with the 4.0. Basically I was wondering if there is any way to pinpoint which O2 sensor is bad so Im not replacing 45 bucks or more worth of O2 sensors. Also any input on what it could be other than an O2 sensor would be appreciated. I leave for school on wednesday. Stuff always seems to go wrong right before I leave for school or home.
jeepjunkie21 is offline   Reply With Quote
Unread 08-18-2014, 04:45 PM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
The Check Engine Light is ON, the code tells you which one is bad, or you can test them all. The Google knows everything, all you have to do is search and read.
P0420 JEEP Catalyst System Efficiency Bank 1
Symptoms
- Engine Light ON
Possible causes
- Three way catalyst converter (the front mini-cats)
- Exhaust manifold leak
- Fuel injectors may be faulty
- Fuel injector leaks
- Spark plugs may be faulty
Tech notes
As the code description implies the P0420 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem.
Description
The Engine Control Module (ECM) monitors the switching frequency ratio of heated oxygen sensors 1 (front O2 sensor) and heated oxygen sensors 2 (rear O2 sensor).A three way catalyst converter (Manifold) with high oxygen storage capacity will indicate a low switching frequency of heated oxygen sensor 2. As oxygen storage capacity decreases, the heated oxygen sensor 2 switching frequency will increase. When the frequency ratio of heated oxygen sensors 1 and 2 approaches a specified limit value, the three way catalyst malfunction is diagnosed.
When is the code detected?
- Three way catalytic converter Bank 1 does not operate properly.
- Three way catalyst converter Bank 1 does not have enough oxygen storage capacity.
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
