Quantcast Catalytic Converter Gone Bad? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Catalytic Converter Gone Bad?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-20-2006, 11:03 AM   #1
johnconners
I'm trying to tell if my catalytic converter has gone bad. Whenever I slow down at a stoplight after going about 40-50mph, there's a burning smell. It happens more often when there is more weight in the Jeep. I accelerate very slowly, but not sure if this a typical speed in a 4 cyl, or slower because of a bad cat. Any help would be appreciated!
2000 [COLOR="DarkRed"]Maroon[/COLOR] [COLOR="Black"]XJ[/COLOR]
4.0L I6, AW4, NP231, 4.5" Rubicon Express Superflex,
31" BFGs on black Cragars, Dynomax Super Turbo, Tomken skids, Warn rock sliders, Front and Rear SYE & custom CV driveshafts, Optima [COLOR="Yellow"]Yellow[/COLOR] [COLOR="Black"]Top[/COLOR], Mopar roof-mounted tire carrier
johnconners is offline   Reply With Quote
Old 04-20-2006, 03:38 PM   #2
iwishihad1
when my cat went bad, i felt like i was draggin a tree, and i got about 8 MPG (without exaggeration) i took everything off, and found a perfect side chunk had broken off, and clogged the outlet of the cat, i gutted it just to make sure it was the cat. and sure enough it ran great afterwards
i have a new converter now though
iwishihad1 is offline   Reply With Quote
Old 04-20-2006, 09:27 PM   #3
johnconners
Isn't it illegal for a shop to remove a cat, but its legal for you to do it yourself?
Old 04-21-2006, 12:53 AM   #4
Muddy Tj Zack
It's illegal to run without one even if you do it yourself....when mine went bad It had no real effects on how it drove. But mine didnt clog up it just rattled really bad.
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!!
Muddy Tj Zack is offline   Reply With Quote
Old 04-22-2006, 07:27 PM   #5
RedefinedTJ
mine makes all sorts of noise.... I need to ditch it soon
RedefinedTJ is offline   Reply With Quote
Old 04-24-2006, 12:50 PM   #6
barry1me
If your 'cat' is rattling that means the substrate or converter brick is broken in to pieces. FYI if this is happening your taking a chance that it will clog your converter outlet pipe and either cause a loss of power, fuel economy, or even put so much back pressure on your exhaust system that your engine wont run. Im a Converter design engineer so we see this every once in a while.
barry1me is offline   Reply With Quote
Glock Forum
